Cruise Control Light Doesnt Work
Old Nov 1, 2003
CIVIKRACIN's Avatar
CIVIKRACIN is an unknown quantity at this point
Question Cruise Control Light Doesnt Work
MY CRUISE CONTROL LIGHT DOESNT WORK
I RECENTLY DISCOVERED THIS.
I INSTALLED A STEREO IN ABOUT A MONTH AGO AND DONT KNOW IF I DID SOMETHING WRONG.
PLEASE HELP!!!
(I THINK THAT IS THE ONLY LIGHT ON THE DASH THAT DOESNT WORK)
Old Nov 1, 2003
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
That's a blessing in disguise. That thing is bright as hell at night! The cruise itself works, right?
Old Nov 1, 2003
CIVIKRACIN's Avatar
YES THE CRUISE CONTROL WORKS (JUST THE LIGHT DOESNT)
I AM HOPING THAT IT IS THE ONLY LIGHT THAT DOESNT WORK
Old Nov 2, 2003
VTEC01EX's Avatar
That light should be on a fuse with at least a few other items... if it's the only thing that's out, I'd say it might just be either a bad connection to that light, or it might actually be burned out. BTW - you might want to check that LED on your keyboard that indicates your caps lock is turned on.
Old Nov 2, 2003
joescivic02's Avatar
Abercrombie and Fitch
if u search i had the same prob u did....... dude its just a fuse... i replaced mione with a yellow light and it took the dealer 5 seconds....so dont worry
Old Nov 3, 2003
CIVIKRACIN's Avatar
THANX I WILL TRY THAT IN THE MORNING
Old Nov 4, 2003
CIVIKRACIN's Avatar
WHERE WOULD THE FUSE FOR THE CRUISE CONTROL BE
Old Nov 4, 2003
crv16's Avatar
crv16 is an unknown quantity at this point
Does the switch work? If so, it's not a fuse problem - it's the little bulb in the switch that burned out. I replaced this bulb on my old Accord several months ago. Just pop the whole switch out from the dash, and a little bulb can be replaced from the rear. The bulb has a little slot for a small screw driver, just turn it 1/8th of a turn and it pops out.
Thing that sucks is that it costs something like $9.00 for this little tiny bulb.
Old Nov 4, 2003
CIVIKRACIN's Avatar
BUT ITS NOT THE SWITCH LIGHT
ITS THE LIGHT THAT U SEE ON THE DASH(IT SAYS CRUISE I THINK)
Old Nov 4, 2003
crv16's Avatar
Oh -- that light.
Same question -- does your cruise control work? If no, then it's a fuse or wiring problem. If yes, then it's probably the bulb in the instrument panel.
Old Nov 5, 2003
CIVIKRACIN's Avatar
the cruise control works
so to look behind the inst. panel
is it just those 2 screws on the top
Old Nov 5, 2003
OHH im sorry man...... its just your light thats burnt out!! yeah i had the same prob.. it works and everything....... its not a fuse.. and yes mine burnt out....... just replace it and your set man
Old Nov 6, 2003
CIVIKRACIN's Avatar
is it just the two screws on top of the inst. panel to get it open
Old Nov 7, 2003
CIVIKRACIN's Avatar
IT WAS JUST THAT STUPID LIGHT THANX EVERYBODY
Tedverseti
Apr 23, 2020 01:45 PM
ORskier
May 3, 2015 12:54 PM
honkeydonkey
Electrical
Apr 26, 2015 08:27 PM
cooldan1
Apr 23, 2015 10:49 AM
SSMatey
Apr 13, 2015 06:09 PM
