oem fog light switch
Old Oct 27, 2003
jkim1978's Avatar
jkim1978 is an unknown quantity at this point
just want a simple question answered... thanks in advance... i want to buy the 0em fog light from tornactive.com... but someone said that swtich wont fit where the cigarettte lighter is.... because the switch is made for 01 civics and 02 civic wont fit correctly.. cause i have a 02 civic... anyways.... if i buy the 02 fog light switch from hondaautomotiveparts.com... then will it fit right in to the harness of the connectors from tornactiev????
Old Oct 27, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
sorry, i've got the 01 and the DEPO brand aftermarket lights, the switch fits fine
Old Oct 27, 2003
asianmatrix02's Avatar
asianmatrix02 is an unknown quantity at this point
I don't think the factory switch will fit the tornactive connectors. i have an 02 and the fogs are made from depo ( same as tornactive i think) and i looked at the factory switch and it has a different type of connector. u might be able to splice the wires from the fogs into the factory switch if u can find out which pins on the switch does what. but what i done on my is dermal out the hole and fit it in there. the hole on the 02 is smaller than the hole for the 01. on the 01 civics the hole is the same size as the cruse control switch.
Old Oct 27, 2003
whitedaze's Avatar
whitedaze is an unknown quantity at this point
From what I've seen of the Honda OEM switch, tornactive's harness will not work with it. As indicated above, you could do some splicing, or maybe even pick up the other end of the Honda harness and just rewire...
Old Oct 27, 2003
jkim1978's Avatar
so my only option is to dremel the hole a little bigger to make the tornactive switch fit in??? how hard was it to dremel??? asian??? and also does it look messy???
Old Oct 27, 2003
whitedaze's Avatar
I had the same problem, and since I passed the wiring harness from the engine bay into the car on the passenger side, I didn't have enough slack to have it reach the other side where teh cruise control and mirror buttons are located. So, I took some wires from an old Computer power supply, spliced the wires on the harness and used those wires to extend it. The button will fit on that side with little effort.
Old Oct 27, 2003
whitedaze's Avatar
I'd think that because of the quality of plastic honda uses for that particular part of the centre console that taking a dremel to it would yeild poor results. And since there is no garnish going around the button the jagged/rouch edges would be exposed. Also, since the button used clips to stay in place, I'm not sure that enlarging the whole would be beneficial anyways if the button would stay in place.
I think your best bet is to do what I mentioned above if you feel up to it. Wires can always be spliced and spliced again but replacing parts is a pain in the ***.
Let us know what you decided to do and how it turns out!
Exterior
Nov 28, 2025 05:23 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
