new coilovers- 33 lbs of torque on all bolts?
Old Oct 25, 2003
usafstud's Avatar
Hey gang,
After a few month of saving up, i'm ordering my coilovers on Monday and I'll be installing it on Saturday. Yes, I'm getting the JIC FLT-A2 for the EP on my 03 EX coupe 5 speed.
my question is, when i put the coilover on, it it 33 lb-ft torque on every bolt? if not, what are the torques for the individual bolts?
thanks,
much appreciated
Old Oct 25, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
yeah, im also waiting for the kw to come in too, how much should i torque the bolts?
thanks
Old Oct 28, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
wow, i want JICs too, lol. but sorry, i dont know the tqs for the bolts...i usually just tighten them down as much as possible, (not too much or i'll strip it)
Old Oct 28, 2003
civicvtec1ps's Avatar
Search and Learn
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear bolt that holds bottom of rear shock:
45ft lbs
Rear two shock tower nuts:
43ft lbs
when i insatlled springs on my car. i didnt bother...
Old Oct 28, 2003
usafstud's Avatar
thanks civicvtec1ps
Old Oct 30, 2003
Logan3024's Avatar
Originally posted by usafstud
thanks civicvtec1ps
Yea, civicvtec1ps is a very informative and helpful member of this site!
Old Oct 30, 2003
havocErnie's Avatar
havocErnie is an unknown quantity at this point
agree
Old Apr 28, 2004
anyone know the part# for
45ft lbs
and
thanks
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
pilebuck13
Sep 21, 2015 10:45 PM
amrhamed
Sep 21, 2015 02:56 PM
