new coilovers- 33 lbs of torque on all bolts?
Hey gang,
After a few month of saving up, i'm ordering my coilovers on Monday and I'll be installing it on Saturday. Yes, I'm getting the JIC FLT-A2 for the EP on my 03 EX coupe 5 speed.
my question is, when i put the coilover on, it it 33 lb-ft torque on every bolt? if not, what are the torques for the individual bolts?
thanks,
much appreciated
thanks,
much appreciated
Search and Learn
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear bolt that holds bottom of rear shock:
45ft lbs
Rear two shock tower nuts:
43ft lbs
when i insatlled springs on my car. i didnt bother...
Front end links:
29ft lbs
29ft lbs
32ft lbs
33ft lbs
33ft lbs
10mm one: 7.2ft lbs
12mm one: 16ft lbs
43ft lbs
top: 28ft lbs
bottom: 29ft lbs
16ft lbs
45ft lbs
43ft lbs
anyone know the part# for
45ft lbs
and
thanks
45ft lbs
and
thanks
2002ExCivic
22
Sep 28, 2015 08:29 AM
pilebuck13
Sep 21, 2015 10:45 PM
