Torn bushings
Old Oct 22, 2003
Naito's Avatar
Naito is an unknown quantity at this point
Unhappy Torn bushings
Just got my car back from Honda after checkup before winter sets in. Had to replace both "lower control arm bushings" because they were torn. Friggin expensive!!
Question is this: what the heck are they, and suggestions for getting better bushings that don't break as easily? any suggestions for the latter welcome, except for "drive slower"
oh yes, their explanation for them breaking was "turning too fast".....I guess spending a couple hours on the track with stock suspension will do that
TIA
Old Oct 22, 2003
Zzyzx's Avatar
Autocross Junky
Suspension techniques makes a set of Lower control arm bushings out of Polyurethane. I check out the bushings every time I swap between my street tires and racing tires. and I need to replace mine too.... One more thing to do I guess
Old Oct 22, 2003
robbclark1's Avatar
Retired suspension supermod.
I got the control arm bushings and both sway bars for around $90. haven't put them in yet though.
Old Oct 22, 2003
Naito's Avatar
what are the bushings tho? what do they do?
no, I'm not trying to eliminate them or anything , just trying to learn
how often do you have to replace these things usually?
Old Oct 22, 2003
robbclark1's Avatar
Energy Suspension makes Polyurethane bushings. They are harder than rubber so that add better turning, but lessen ride quality. They should never be replaced, maybe lubed sometimes, but not replaced. If you are racing then they are a good upgrade.
Old Oct 22, 2003
lberry's Avatar
lberry is an unknown quantity at this point
I have the same problem with my bushings...Theay are starting to crack.
Anyone know if the Prothane Brand bushings are any good?
I am seriously thinking about gettting the Total Kit 8-2019 for $147.33
http://www.lightningmotorsports.com/prothane.htm
Old Oct 22, 2003
robbclark1's Avatar
I would call Prothane and ask what is exactly included in that kit. I don't believe that we have shifter bushings because of the cable shifter. If it is only the control arm bushings then you should be able to get front and rear ES bushings for less than that.
Old Oct 22, 2003
JayFReaZy's Avatar
Last time I went to honda, they said I need to replace my right control arm bushing. Im wondering too, what exactly does it do? I havnt replaced it, and I dont know when I am. Its been a while I've been driving that my right control arm bushing has been "cracked" or something like that. Can someone explain what exactly it does, and the effects it has on your car if you dont fix it?
Old Oct 22, 2003
lberry's Avatar
good idea, I'll give them a call after work. I was just curious if you guys have heard anything good or bad about that brand........I think I might go for the Energy Suspension bushings since I only need control arm bushings right now.
Where did you order yours from?
Old Oct 22, 2003
robbclark1's Avatar
Control arm bushings buffer the vibrations from the wheels. The wheels move up and down on the control arm and the bushings help cushion it. They are like motor mounts. when you stop, the motor goes forward, and the rubber bushing cushions the motor. The stiffer the mount the more vibrations or road you feel, but you get better suspension performance because there is less lateral movement. That is my understanding of them.
i got my from www.pnatic.com They sponsor my car club. They don't list them on their site but they can get them for you. Lightening motorsports has them too i think.
ThatGuy913
Sep 28, 2015 05:35 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
czarlun
Sep 14, 2015 08:16 PM
