Sportlines or Prokit?
Old Oct 19, 2003
Civic02playa's Avatar
Civic02playa is an unknown quantity at this point
Hey everyone.....here is my dilemma....I want to drop my 02 civic enough to the point where I have on driveability problems.....and someone suggested the prokit to me but i want a little more than an inch so i was thinking the sportlines......so if anyone has any prefernce one way or the other it would be great......thanks......and im pretty much only looking at springs right now and keeping the oem struts...thanks in advance
Old Oct 19, 2003
civicvtec1ps's Avatar
Search and Learn
prokit or sportlines. you will probably have to replace oem struts eventually, its just matter of time ,road conditions etc.. i would go with lower drop than prokit though , 1".. not low enough. just get whatever you like, and save up for new struts for the future
Old Oct 19, 2003
See thats the thing like there are high curbs around here and potholes........so i dont want to run into any problems hittin.....that is why i want to go w/ the 1.4 because i dont think i will but if anyone knows from experience that would be awesome.
Old Oct 20, 2003
flotsamm's Avatar
Go for the Sportlines. I have a set and do over 300 miles a week in my car. The ride is close to stock, but a little rougher and bouncier on stock struts. I've only scraped once going over a really tall speed bump with a couple of friends riding with me.
Eventually I'm going to replace my struts with some KYB's or Tokico's since I dont like the Koni design.
Old Oct 20, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
You should also check out tein s-tec, 1.3" front and 1.4" rear. It is also cheaper around 130ish at www.groupbuycenter.com
Old Oct 20, 2003
BlackSI's Avatar
BlackSI is an unknown quantity at this point
either one is pretty good spring, but like the others say there is still the prob of stock shock. hopefully tokico or one of those other brands will save the day with a replacement that doesnt require any cutting of stock strut
Old Oct 20, 2003
Thanks a ton you guys for your replys so quickly........i'm def considering the tein s-tec's....if someone could tell me in comparison which one is better though the sportlines or the teins it would be greatly appreciated.......the only reason i ask is that i have heard soo many great things about the eibach's so that is only why im partial to them....at the same time tein has been known for their suspension technology.....but from personal preference if you guys could inform me it would be greatly appreciated.....thanks in advance
Old Oct 20, 2003
Amplify's Avatar
Amplify is an unknown quantity at this point
Just a heads up, Sportlines might be listed as a 1.4 drop, but it's actually more around a 1.75 drop. The 1.4 measurement is BEFORE they settle.
So if that's the case, I'm guessing the 1 inch drop listed for the Pro-kit is probably a bit lower after they settle too.
Old Oct 21, 2003
mootlif3's Avatar
mootlif3 is an unknown quantity at this point
The pro-kit is about a 1.4-1.5 inch drop after they settle. It doesn't look bad and you won't hit much to anything, but I personally want to go lower.
Old Oct 21, 2003
so i take it mootlif that you have the prokit but you would rather go w/ the sportlines?.......if thats the case then i'll most likely go w/ the sportlines but i might have to go w/ the prokit.....who knows....thanks again though guys for lettin me know
Old Oct 22, 2003
Marion26's Avatar
Marion26 is an unknown quantity at this point
Trust me if you put sportlines and put on a kit you will scrape the sh#t out of it had my sportlines for two years and they have settled to a 1.75 drop now so I think pro kit will work out nice just my 2 cents
Old Oct 22, 2003
dezod's Avatar
7thgen Power Maker
We have a GB for them now!
http://www.7thgencivic.com/forums/sh...hreadid=121338
Old Oct 22, 2003
Thanks for everything you guys.......I'm def. going w/ the prokit.......thanks again for everything and for all the replies so quickly!
VNlilMAN
35
Aug 22, 2002 10:42 PM
BAK
Apr 13, 2002 03:41 PM
CivicS
Mar 11, 2002 11:43 PM
CivicPro01
Feb 18, 2002 06:00 AM
Ramen
Jan 30, 2002 11:23 AM
