on camber kit
Old Oct 21, 2003
smokedcivic's Avatar
"SLIPSTREAM R"
smokedcivic has a little shameless behaviour in the past
Question on camber kit
do you really have to have a camber kit, i found another way to reduce the camber in my alignment, i don't know if it is the same as a camber kit though
can someone post a pic of a camber kit on the site or in this forum to help me out
thanks in advanced.
Old Oct 21, 2003
TeLLy's Avatar
Yes, it's an Acura EL
What is your other way to reduce camber?
Old Oct 21, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
did you need to replace any parts for this other method of reducing camber?
Old Oct 21, 2003
"SLIPSTREAM R"
no all i did was add shims to the same spot you put the camber kit and used a longer bolt.... thats what i was gonna do anyway.
Old Oct 21, 2003
TeLLy's Avatar
Front/rear/both?
Old Oct 21, 2003
"SLIPSTREAM R"
just the rear..
Old Oct 21, 2003
TeLLy's Avatar
Pix? Full DIY?
Old Oct 21, 2003
R1Style's Avatar
To adjust camber, you need to replace the entire upper control arm.
This is a picture of the SPC Rear camber kit
I guess you could use longer bolts but I'm not sure about that. You'd have to buy specific bolts that are exactly the length you need and it differs from height (the lower the drop, the longer the bolt would have to be). Plus it would be way easier to just buy a camber kit to adjust camber.
But if you've done it, could you post some pics and the parts you used.
Old Oct 22, 2003
"SLIPSTREAM R"
well what i wanted to do was add 1/2 inch of shims to the top control arm and work form there its obviously not as accurate as the camber kit but it serves the same purpose, i know that that is what people used to do ont their cars in the old days....
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
