Questions about stripped lug bolt
Old Oct 14, 2003
WD40's Avatar
WD40 is an unknown quantity at this point
My Powerslot rotors arrived yesterday and I began happily installing them. The driver's side went on absolutely perfect, which should probably have tipped me off that the passenger's side was going to be a bitch.
It all started when I tried to remove the wheel. Seems one of the lug nuts got cross-threaded. How the hell that happened I don't know. I drove it down to a local mechanic and had him remove the nut with an air wrench, which stripped out the nut and stripped all the threads off the lug bolt - but I expected that.
I took my car back home, pulled the wheel off and attempted to remove the rotor. The two phillips head screws that hold it on were frozen in place, and I didn't have any WD-40 handy, so I had to put the wheel back on and go buy some. I manged to get one screw to break free, but the other wouldn't budge. By this time I was already late getting to my girlfriend's house, so I put everything back together and gave up for the time being.
I called Midas today to see if they could replace my stripped bolt, and they said it would be ~$80.
I have a couple questions, maybe Grey will have some insight on this one: What is involved in replacing a lug bolt? Would I be able to do it myself?
What other shops should I check for a lug bolt replacement? I don't really want to spend $80 on it.
I figure I'll have the slap the other Powerslot on while they're at it since they have to remove the rotor anyway They'd better do that for no extra charge too!
Old Oct 14, 2003
CarbonFly's Avatar
DIY, I stripped one of my lug bolts at the track on sunday. It's a $4 part to replace. Just pull off the caliper and put the new bolt on yourself. That's what I'm gonna do.
Old Oct 14, 2003
03civicdx's Avatar
03civicdx is an unknown quantity at this point
easy procedure, should basically pop on and off, i replaced all four on my old acura legend and it was like 8 bucks a piece (possibly 4 for civic dont know) and it came out and went in easily, good luck
Old Oct 14, 2003
WD40's Avatar
I'm a little confused. You say the lug bolt just pops off? So what, you smack the tip of it with a mallot until it comes out the back of the hub, then tap another one in?
Sorry, I'm having trouble getting the whole mental imagery thing goin.
Old Oct 14, 2003
blustrek01's Avatar
blustrek01 is an unknown quantity at this point
i hate to tell you this but you can not do it yourself. the hub has to be pulled. i had the same thing happen to me, i tried to do it myself and found that the stud dosen't clear the back side of the spindle. take it to a shop or dealer and let them do it. also what kind of lug nuts do you have on your car? when i bought my car i got the wheel option and the lugs they put on were grey and look like alluiminum. they are the reason you x-threaded the lug. they are to soft of a material. i recommened that you replace all your lug nut or you will have to do it again in the future. good louck.
Old Oct 14, 2003
WD40's Avatar
I dropped it off at Big-O on my lunch break. They said they'd replace the bolt and install my Powerslot rotor while they were at it for $35. I'm happy with that.
My lug nuts aren't aluminum, they're definitely steel. What quality steel I'm not sure, but they seem to be pretty good quality. I don't know how it got cross-threaded. I put that weel on about a week ago when I changed my brake pads, and I know I didn't cross-thread it when I put it on. I always start the nuts by hand and then torque them down with a wrench. I dunno. Oh well.
Old Oct 14, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
You tightened them too much...happend to me too...i replaced it myself though...it's not that bad if you have air tools...
manfredww1
Jul 14, 2015 10:24 AM
NoobyKid
Jul 13, 2015 07:53 AM
trellex
Electrical
Jul 9, 2015 12:01 PM
ballmich
Jul 9, 2015 11:59 AM
CivicsClass101
Jul 9, 2015 11:14 AM
