Si K20 VS. RSX K20?
Resident Tough Guy
I was searching (through hundreds of posts, Ugh) to find something that I couldn't quite find.
I was wondering why the K20 from the RSX is so expensive? Is it because they are so rare right now? Or is it because of the engine itself?
I was thinking that if someone wanted to, they could take the K20 from the SI Hatch and swap it into the 7th gen coupe and turn it into the new si coupe that they really should have made instead of the si hatch in the first place.
But would it necessarily be cheaper to get a K20 from and SI rather than one from the RSX? Just curious, cuz I think that would be sweet to take the SI engine and swap it in and slap a good ol' SI emblem on the coupe.
-Cheaper meaning would the swap be cheaper to perform (parts/labor)-
Post Whore General
The RSX type S has the K20A2 in it. With that motor you also get a 6-speed tranny, true DOHC VTEC and a redline of 8000 RPMs.
The 02-up Civic SI and base RSX have the K20A3 in them. That motor comes with a 5-speed(or auto in the base RSX) and a redline of 6800 RPMs. Plus the K20A3 only have VTEC on the intake cam, so you do not get true VTEC with that DOHC motor. Last thing, the K20A3 in the base RSX come with a plastic intake manifold. Were the K20A3 in the 02-up SIs intake manifold is not plastic.
I hope this helps.
I hope this helps.
Resident Tough Guy
I hope this helps.
I hope this helps.
So I take it from what I read here that the K20A3 will be a cheaper swap than the K20A2?
Thanks for the great info everyone.
Post Whore General
You would not be able to use the D17 tranny with the K20 motor. And it would not really be worth it to swap in the K20A3 motor. Because the cost to install it would be the same for the K20A2 and with the K20A3 you would be getting only 33hp more. Not worth it.
^^ Exactly ^^ All of the "difficult" things need to be done when swapping either K20. Therefore, job complexity and labor costs will be roughly the same. Spend the extra grand (roughly) and do it right.
Originally posted by andyman97
If I were to do the swap now that the k24 is out, that would be the one I'd do. k24 block with k20a head from a type r, boost that and compare it to a k20a2, muahaha.
Post Whore General
The K24 block is found in the new Accords and CRVs. And both of them have Vtec on the intake cam only. The head on the Accord and CRV K24 motor is the same head that is on the K20A3, but the difference is that the cams are smaller in the K24. The K24 motor in the TSX is basically the frankenstein K-series motor. It is the K24 block(of course) with a different compression, The K20A2 head on it, Vtec on both intake and exhaust cams, and a 6 speed tranny. Its redline is like 7200 I believe. The TSX K24 motor has 200hp and 166 ft tq. This motor would have tons of torque with a supercharger on it. But the only problem with swaping this motor in is that the block is taller.
I drove both the brand new rsx s, and a tsx at the dealership and in the rsx u can acvtually feel when vtec comes in, coz it starts pulling u nice and hard much like the older generation b series motors, (like gs-r, type r ) but the tsx doesnt pull like that, only the rsx s does
The K20A2 would be your high-revving torqueless wonder, yet the wide powerband makes it fun to drive with the lively VTEC to compensate for what the other engine has.
The K24 block has something the K20s don't have - more displacement, and more displacement means more torque. You can either have torque, or less torque and VTEC n/a.
It shouldn't be surprising if the RSX feels livelier given both engines are 200HP with the K24 having just a lil' bit more torque. The RSX is around 400-500lbs lighter than the TSX and it's additional torque can't make up for it's weight in stock form.
However if the K24 was in a lighter chassis, that would be a different story.
Post Whore General
Originally posted by SlammedBlueEM2
I thought it was just the intake manifold? (In comparison to the other K blocks.)
#1 S2000 Fan
Since when did the Hasport civic sedan have a K24 block under the hood? I thought that they still had te K20A2, but boosted by cybernationmotorsports.
The hasport Civic has the Type S under its hood. However it may soon have a K24, because Hasport is suppose to have the mounts for the swap by the end of the summer. Clearance must not be an issue with the swap, if they are making the mounts for the swap. It still could require a new hood though if clearance is a problem. I'm just wondering who on the site will be the first to do the K24 swap. I've heard that engine is like boat loads heavier than the Type S which is already heavier than the regular D17. I wonder how the car would handle the heaier load as far as ride.
#1 S2000 Fan
Well personally I wouldl think that swapping a Si motor wouldn't be a bad idea if you could get it at a fairly low price. Like lets say 2,000 to 2,500, which I think could be possible since the market is mainly for the K20a and the A2. I mean for some people you might only look at is as only a 33 horsepower upgrade, but its more than that.
You are getting an engine that is more supported by the aftermarket, you are getting a more tunable engine (one that companies actually do have a supercharger for). All in all its just a much better platform to start with instead of the D17. You can ask any person who traded in their EM for an EP. Why did they do it? You know it wasn't looks. They wanted the potential. The K-series offers that.
I mean hell people swap the K20A2, why didn't they just swap the K20A. I guess its just a money issue.
Which is the main reason I am a fan of the A3 swap.
But hey if the K24 swap is just as cost effective that might become popular too.
YES, it is still a type-s (2.0) block in the Hasport car.
Ripped from Car and Driver:
"An RSX Type-S 2.0-liter four-cylinder booted the stock 1.7-liter motor and came replete with an AEM engine-management system, a custom intake, and a Rev Hard turbo system good for about 6.5 psi of boost. AEM claims an output of 349 horsepower and 239 pound-feet of torque delivered to the front Yokos via an RSX Type-S six-speed manual, a Japanese-market limited-slip differential, and a Clutch Masters clutch and aluminum flywheel."
I'll slap a K24 in early next month to make sure the mount kit fits properly. But we are going to leave the K20 in for the next year most likely. We plan on upping the boost into the high twenties or low thirties for some drag racing.
brian g
brian g
Dave88LX
Electrical
15
May 28, 2020 08:31 PM
PunX
Sep 23, 2015 10:45 PM
