Eurolite underdody neons
Hey I just got some blue eurolite under body neons and got them installed today. They seem to be very dim, and the side and back tubes only glow from the two end but not the middle {it fades out). Can somebody help me with this- i mean these are supposed to be good, they arent some ebay kit. thanks in advance
why, why would you get eurolite instead of street glow!? but check the ground and makes sure its tight on BARE metal. do you have a voltage meter, check to make sure enough power is getting to them. is the front one a solid glow? ...like not fading in the middle like the rest? check the connections and make sure they are nice and tight also...did you install it or have it installed?
I had it installed, but even the front one is faded. is that just a bad ground? and im not sure about this, but when I touch the actual tubes under the car briely they become brighter- i have no experience with this..
when i touch them with my finger. The Rear tube turns on from one side, but when i touch it with my finger (just tap it), it turns on at both ends but not the middle.
SLeePeR012
Mar 2, 2002 11:00 PM
