Eurolite underdody neons
Old Aug 7, 2003
MegaCivic2k1's Avatar
MegaCivic2k1 is an unknown quantity at this point
Hey I just got some blue eurolite under body neons and got them installed today. They seem to be very dim, and the side and back tubes only glow from the two end but not the middle {it fades out). Can somebody help me with this- i mean these are supposed to be good, they arent some ebay kit. thanks in advance
Old Aug 7, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Maybe the techies in the Tech Stuff forum can help you out on this ...
--> moved to Tech forum
Old Aug 7, 2003
Anyone?! come on..... ANYBODY?!
Old Aug 7, 2003
khmaitiger's Avatar
khmaitiger is an unknown quantity at this point
its not getting enought power.. liek the ground may not be good.. or the car is using the power for somethign els.. or its just hooked up wrong
Old Aug 8, 2003
EnProceso's Avatar
why, why would you get eurolite instead of street glow!? but check the ground and makes sure its tight on BARE metal. do you have a voltage meter, check to make sure enough power is getting to them. is the front one a solid glow? ...like not fading in the middle like the rest? check the connections and make sure they are nice and tight also...did you install it or have it installed?
Old Aug 8, 2003
I had it installed, but even the front one is faded. is that just a bad ground? and im not sure about this, but when I touch the actual tubes under the car briely they become brighter- i have no experience with this..
Old Aug 8, 2003
EnProceso's Avatar
by touch do you mean with like a finger or move them around a little, could be loose connections.
Old Aug 8, 2003
when i touch them with my finger. The Rear tube turns on from one side, but when i touch it with my finger (just tap it), it turns on at both ends but not the middle.
Old Aug 8, 2003
khmaitiger's Avatar
yea thats power problem
Old Aug 8, 2003
khmaitiger's Avatar
go back wher eu got it installed and tell them there somethign wrong with the power mostly likely ground and ask them to check it out
Old Aug 8, 2003
DUGMAN's Avatar
DUGMAN is an unknown quantity at this point
yea the power is not getting there loose connection, I had the same problem. And your lights should be bright, Streetglow are okay but my aerpro's are the brightest you can buy.....
Jeffdp
Jun 18, 2015 06:18 PM
ROBREALZCIVIC
Mar 14, 2002 06:21 AM
viper775
Mar 5, 2002 04:44 AM
SLeePeR012
Mar 2, 2002 11:00 PM
Oishi
Canada West
28
Feb 18, 2002 08:24 AM
