Sponsored by:
Sponsored by: CARiD
Dx Exhaust Problem
Old Jul 26, 2003
Big Baller L's Avatar
Nugget Garage Since 2004
Dx Exhaust Problem
I own a dx sedan and when i first got the car i bought dc headers off ebay, cuz i thought they would fit. Obviously i figure out that they wont fit, but i was wondering if i could buy an aftermarket ex downpipe, and bolf on the headers and down pipe. I know the o2 sensor needs to be before the cat and after the cat, but i could extend the wires to easily do that. I had a bung drilled into the header so i could put one there, and another after the cat. If anyone knows if this would work or not i would appreciate ur input. Thanks
Old Jul 26, 2003
Project2k2's Avatar
THis is what I am doing. I also have the Dx but I am buying the HP racing header with the downpipe that eliminates the Cat. Then I am buying a aftermarket EX exhaust system, that's the only way it would work....so basically once u get the downpipe, you will still need to buy either a stock EX cat back or an aftermarket cat-back....Hope that helps.
Old Jul 26, 2003
hmmm...aight well i have a sedan also. So ur headers have no cat....do they have a downpipe or did u get a different one. I have th dc sports and ive seen downpipes whice relocated the cat to underneath the car. So u think this setup would fit?
Old Jul 27, 2003
has anyone else on the site tried this?
Old Jul 27, 2003
pheaton's Avatar
A descendant of 2k1civic.com
I have an LX, so I dunno .. Anyways. . What you want to sounds like it would work though. . Might have a problem with the check engine light though, just so you know. .
Old Jul 27, 2003
really?? why would that be a problem??
Old Jul 27, 2003
pheaton's Avatar
Our cars are sensitive with the emissions. . When you mess with the exhaust or intake you risk that light coming on.
Old Jul 27, 2003
really...that sucks....but wouldnt it stay the same if they got relocated??
Old Jul 28, 2003
pheaton's Avatar
No idea. . There is something you can buy to keep that light off though. . I'll let your know if I can ever remember what it is called. I'm not sure if the dealer can re-program the light if it comes on or not .
Old Jul 28, 2003
pheaton's Avatar
Ahh. . it's called an MIL eliminator. . I'm not certain if this is 100% necessary, but I know that it's purpose is to keep the light from coming on.
Old Jul 28, 2003
pheaton's Avatar
But. . now that I read more. . The the MIL is being used in an LX when you remove the CAT. So you might be ok with a DX.
Old Jul 28, 2003
hmm...but wouldnt that mean it wouldnt come on if something else went wrong?
Old Jul 28, 2003
pheaton's Avatar
I'm asking Azure to stop by this thread . . He probably knows more about the MIL then I do, because what I know about it, I read on his post where he is selling his exhaust headers.
Old Jul 28, 2003
XtremeJM's Avatar
hmmm.... i was wonderin all this too, glad to know my LX needs to be modified.
Old Jul 28, 2003
aight hopefully the dx wont be an issue...but i really need to pump out all the power i can from this engine....untill i save enough to swap
Old Jul 28, 2003
pheaton's Avatar
True. . I'm sitting on the same engine guy. . So I feel ya.
Old Jul 28, 2003
haha aight...u knwo what im sayin then....like nicely slow
Old Jul 28, 2003
azure's Avatar
Doesn't the downpipe have to be long enough in order to eliminate the CAT? Or did you mean High Flow CAT that comes with the HP header for the EX? If so, I don't think it eliminates the CAT. It's basically just a thicker downpipe.
Also, if you have an LX/DX and want to get an exhaust system made for an EX. You will also have to get the Front Sway bar for an EX. This is so the CAT will fit.
Old Jul 28, 2003
sway bar?? what i wanna do is use the header that i have...and then find an si/aftermarket downpipe...and then attach that to an aftermarket midpipe...then to my over axle muffler...the downpipe still has the cat, but it is under the car...in the dx the cat is in the engine bay right under the headers
Old Jul 28, 2003
azure's Avatar
Hmm. . . are all the aftermarket parts you mentioned made for a DX? or EX(Si)? I'm guessing it's made for an EX because yo mentioned that the CAT would now be under the car.
Old Jul 28, 2003
ummm im not sure....they arent for a dx, cuz nobody makes them....so maybe ex....im not sure i dunno...i should find out...my headers are dc sports
Old Jul 28, 2003
azure's Avatar
The check engine light should be no problem for you because it sounds like you still want the CAT. Just as long as you have an o2 sensor before and after the CAT. The MIL Eliminator is used only if the CAT is completely removed.
Okay, so since you're keeping the header you have now [which is made for an EX, right?], you would basically use an aftermarket exhaust system made for an EX.
But since your CAT would be relocated to under your car, you would need the front sway bar from an EX. The EX front sway bar is made so that the CAT will fit:
And because the LX/DX/HX has the CAT right under the header:
The front sway bar [for the LX/DX/HX] is not made to fit a CAT.
Old Jul 29, 2003
yah i wanna keep the cat...but i just want better flow so headers...downpipe....midpipe. But in order for the downpipe to fit i need the ex sway bar?? Is that so the downpipe will have something to clip onto?? Like the hangars nees the sway bar with the plastic thingy on it??? I might be able to get my hands on a si downpipe/cat...would that work??
Old Jul 29, 2003
azure's Avatar
I'm thinking you need the EX sway bar in order for the cat to fit. Check out this thread.
And it might also be because of what you mentioned about the hangers. That could be another reason why, but I'm not sure.
Old Jul 29, 2003
hmm was that guy just putting on a hi flow cat? I bet if i got an si downpipe it would fit, cuz the cat is like under in the middle. Im sure my stock exhaust has hangers in the same areas. I think he was saying that if u only want to replace the cat that the ex one wont fit the lx because of the sway bar. The thing is i dont even know it the dx has sway bars. I really need to find someone that is doing it, and ask them...
Old Jul 29, 2003
azure's Avatar
Yah, you might want to ask people. I'm not sure about this exhaust system deal and I don't want to give you the wrong info. Good luck though.
Old Jul 29, 2003
aight well thanks for the info anyways!
Old Jul 29, 2003
azure's Avatar
No problem.
Civic2002lx
Oct 7, 2015 09:17 AM
juror
May 26, 2015 06:35 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civic4ever1996
Apr 16, 2015 08:30 PM
MY01HX
Nov 12, 2001 04:25 PM
