KNOCKING NOISE when turning: resolved
Well this has been going on for a while now. I finally got time to take it to the dealer. The first time I took it they tried to blame it on the Neuspeed sway bar....
I took again a couple weeks later and I had the tech ride with me around the lot to hear the knocking when I turned the wheel about 40 degrees to the left and right at low speeds and parked. Honda said it's the springs coming into contact with something. They had to order 2 new front springs and now the 2001 coupe is in the shop as we speak. I will let you know the outcome to see if this fixes the knocking. Hopefully this will help any of you having this problem. Just so you know I have 35k and it's a warranty issue so it's covered. I'll keep you all posted...
Coastie
I took again a couple weeks later and I had the tech ride with me around the lot to hear the knocking when I turned the wheel about 40 degrees to the left and right at low speeds and parked. Honda said it's the springs coming into contact with something. They had to order 2 new front springs and now the 2001 coupe is in the shop as we speak. I will let you know the outcome to see if this fixes the knocking. Hopefully this will help any of you having this problem. Just so you know I have 35k and it's a warranty issue so it's covered. I'll keep you all posted...Coastie
Sep 26, 2023 06:44 PM
CraigW
Aug 18, 2015 07:06 AM
15EXCoupe
Jul 30, 2015 12:59 PM
17
Jul 23, 2015 11:48 PM
