what's a camber kit
Old Jul 13, 2003
somean2's Avatar
somean2 is an unknown quantity at this point
what's a camber kit
can anyone tell me??? thanks
Old Jul 13, 2003
Voiceofid's Avatar
End Bringer
"what a camber kit does is realign your tires. if you drop your car more than 2 inches your tires start to go inward. you can actually see this if you get behind your car and look and both rear tires. if you dont't get a camber kit what will happen is you will get uneven tire wear. you'll start to see your tread disapear much quicker then if you had your tires straight. you'll also get better traction with your lowered ride if you get a camber kit because it puts your whole tire on the ground as suppose to just the insides of your tires. hope this helps " - aemtunedcivic
Old Jul 13, 2003
Amplify's Avatar
Amplify is an unknown quantity at this point
Camber kits are used to adjust the inward or outward tilt of your tires as compared to a "perfect" perpendicular setting. Hondas don't come with a way to adjust camber, so a camber kit is needed.
Old Jul 13, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
Almost ALL cars with the ability to adjust camber. They have to. What they don't have to account for is the added capacity to adjust for suspension drops. It's this EXTRA amount of adjustment needed with many suspension drops that will make it neccesary for the application of a camber kit to take up that broader angle.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
