check engine light
Old Jul 7, 2003
sandgrencivic's Avatar
sandgrencivic is an unknown quantity at this point
Question check engine light
Well my check engine light came on. I went drag racing last wednesday. And I was running about 97 octane, cause I dumped some 110 mixed with 87. Now the 110 is leaded, so did I mess something up. My car ran a lot better. I think that my cat got hot, and needs to be reset on the sensor. Any suggestions??
Old Jul 7, 2003
EnProceso's Avatar
lead from the gas will f*ck wih your cat. converter!! seesh didnt you read the manual! theres a reason it says unleaded ONLY.
Old Jul 7, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
eventhough i cannot provide a useful answer, common sense tells me that you did f*ck it up....
What was that term called....when the engine runs higher octane and ignites faster? hmm.. anyway it was NOT good at all.
My cheap unproven suggestion: Keep dumping 87 from now on.... no more racing fuel for you buddy.
Old Jul 7, 2003
Green Civic's Avatar
Drain the fuel in the system and fill up. Problem should be fixed or a little gas in the engine should filter its self out. Hopefully you learned not to mix unleaded with leaded.
Old Jul 7, 2003
I still dont fully understand this situation. The reason, because it has been proven that leaded gas burns better in an engine, however it is not as environmentally safe. I know that it does not hurt the engine, because I run sand rails with straight 110 octane, in subaru, and honda accord engines. So is it just the 02 sensor that is knocked out? Or maybe the cat. I filled up a new tank of gas so I will see if it flips the light off, if not I am due up for my 30K mile checkup.
Old Jul 7, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Not sure if this will mean anything to you, but this is straight out of our manuals:
"Using gasoline containing lead will damage your car's emissions controls."
Can't be much clearer than that.
The ULEV requirements on the 7th gen engines may also make them more sensitive to lead than those other cars you drove.
Hopefully there isn't any permanent damage, cuz any repairs related to emissions is expensive as hell... and I doubt Honda would fix it under warranty if they detect lead in your system.
Old Jul 8, 2003
hubersbernd's Avatar
hubersbernd is an unknown quantity at this point
The lead in the gas coats the chemicals in the catalytic converter and renders the converter useless. That is why the Check Engine Light came on.
If you have done enough damage you find yourself in need of a new converter...
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
