Accumulated turbo parts...
Old Mar 10, 2004
  #31
Big Baller L's Avatar
Nugget Garage Since 2004
^^you need more fuel to accomodate for the extra compression, to prevent detonation and messin **** up!!!
tek:so ur gonna build a manual boost controller thing? Cool....also for ur air/fuel gauge i wouldnt reccomend getting the aem one. I dunno it bounces around alot, and never really seems to give an accurate reading on what is going on, and when ur talkin bout boost u wanna make sure ur not running lean, but it might work i dunno!! anyways good luck!!!
edit: check this thing out if u still need a air fuel gauge. A little pricey
http://www.7thgencivic.com/forums/sh...hreadid=143569
Old Mar 11, 2004
  #32
tekgnosis's Avatar
Ask me about your mom.
sweet, thanks baller!
yeah, I need something REALLY accurate for the air/fuel gauge, as that's what I'll be using to setup the air/fuel ratio after I install the turbo.
I'll be getting the HKS S-AFR (Super Air/Fuel Regulator) for the fuel management.
Also, the injectors have been ordered and should be here sometime next week
little by little, the project is coming together. sooo slow, but at least it's keeping me busy
EDIT: Baller: d00d, seriously, buy me that air fuel gauge hehehe it's so ****** tight! keep your eye open for this, but cheaper hehehe It's now officially the gauge I want!
Old Mar 11, 2004
  #33
^^yah i saw it and automatically though about a turbo set-up. Its really sweet cuz it comes with the wideband sensor and it has digital reading plus electric like the other ones! You might be able to craft ur own out of a gauge and just buy a wideband sensor. I can't wait to see all ur parts. Lemme know when ur gonna install cuz id love to come and help and learn as much as possible
Old Mar 11, 2004
  #34
tekgnosis's Avatar
for sure, d00d!
still a long way to go with collecting the parts and all, but hopefully by the end of the summer I'll be able to install it all. hopefully
Old Mar 11, 2004
  #35
gohanix's Avatar
gohanix is an unknown quantity at this point
are you going to use it in winter as well?
Old Mar 12, 2004
  #36
tekgnosis's Avatar
yup. it'll perform better in the winter actually, because cold air is more dense.
my only concern in the winter is leaving the fuel computer out in the cold cuz the screen (lcd) will freeze and *** up the pixels
Old Mar 12, 2004
  #37
gohanix's Avatar
cant you unplug it and replug it when you need to?
Old Mar 12, 2004
  #38
tekgnosis's Avatar
yup. it's just annoying, that's all.
Old Mar 20, 2004
  #39
Dasica's Avatar
Dasica is an unknown quantity at this point
Would a homebuilt turbo give the same power as the one specifically built for the 01 civic?
Old Mar 20, 2004
  #40
gohanix's Avatar
it can depending how well you build it
Old Mar 21, 2004
  #41
tekgnosis's Avatar
Dasica: yup. if you build it right, it can make more. But, I'm not interested in peak power...I'm interested in a quick spooling turbo that can deliver maximum boost at a low RPM.
All while being REALLY reliable.
Old Mar 21, 2004
  #42
Tofast4me's Avatar
Tofast4me is a glorious beacon of lightTofast4me is a glorious beacon of lightTofast4me is a glorious beacon of lightTofast4me is a glorious beacon of lightTofast4me is a glorious beacon of light
Tek can you let me know as well when you are installing? I am pretty interested and i promise I won't get in the way. Just would like to help?/learn how you put it together.
Old Mar 21, 2004
  #43
gohanix's Avatar
ditto dude...
Old Mar 22, 2004
  #44
Si2NV's Avatar
me too...I promise I won't get in the way too
Old Mar 22, 2004
  #45
Dasica's Avatar
Keep us updated I'm going to go to that website, sounds alot more interesting than just buying a premade one.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
