Retail Sales - site vendor annoucements Place for Vendors to post their specials and new stuff coming out or just advertise prices. These Vendors have been approved for posting in this section. Don't see anything new? PM them!
Denso IK20 Spark Plugs!
Old Aug 16, 2005
dezod's Avatar
7thgen Power Maker
In stock!
$51 shipped for the set of 4!
http://dezod.com/pd_denso.cfm
Old Aug 17, 2005
dezod's Avatar
7thgen Power Maker
No one?
Old Aug 17, 2005
dj02's Avatar
ill be puting in a order next week
Old Aug 17, 2005
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I'll probably order pretty soon. These come pre-gapped to fit our Civics? On the site there isn't an option to choose which car these are gonna be for.
Old Aug 17, 2005
jttegx's Avatar
OMNES AD UNUM
i dont know much about spark plugs, but would this be a good investment even if your factory plugs are still fine? what are the improvements and how does it work?
its a fairly new civic and runs fine, but its tested and proven that it can get better mpg (and performance), i might be interested.
Old Aug 17, 2005
dezod's Avatar
7thgen Power Maker
These come pre-gapped. The IK20 fit several applications other than the Civic. That is why there is no 'vehicle option'.
http://www.densoiridium.com/find_part.php?type=auto
To find out what other cars the IK20 may fit
Couple of testimonals!
http://www.densoiridium.com/tunerstales.php
Dyno results!
http://www.densoiridium.com/dynochart.php?id=1
'DENSO Iridium spark plugs require on average 5,000 fewer volts to fire than conventional spark plugs' --From Denso's Site
Q. What makes Iridium better?
A. Until recently, platinum was considered the best material to use on the top of an electrode because of its durability. However, Iridium is 6 times harder, 8 times stronger, and has a melting point 1200 degrees higher than platinum. Put that into a harsh environment such as an engine piston chamber, and you have a spark plug that can resist wear much better than platinum. Additionally, the DENSO Iridium Power alloy is so durable; it allowed our engineers to produce the world’s smallest center electrode (.4mm) which reduces the voltage requirements, concentrating its sparking power. Also, its smaller size, combined with the tapered U-Groove ground electrode, allows more room for the flame kernel to develop and produce a more efficient combustion.
Q. Why are there different heat ranges? Which one should I use?
A. Part of your spark plug’s responsibilities, in addition to firing a spark, is to remove heat from the combustion chamber. This is accomplished by channeling the heat through the insulator material and metal housing. From there, the heat is transferred to the cylinder head where the engine cooling system can go to work. A spark plug’s heat range is its ability to dissipate heat. The “colder” the plug, the more heat it can channel out of the combustion chamber. In a performance application, colder heat ranges may be necessary to handle the extreme temperatures brought on by higher compression ratios, forced induction, and high RPM’s. While “Colder” plugs may seem to be the way to go, please remember that the spark plug must achieve its “self-cleaning” temperature where it can burn off fuel and carbon deposits. Otherwise, the plug could “foul out” where it is prone to misfiring and poor acceleration. A plug that is too “hot” can overheat, also causing power loss, detonation, pre-ignition, and possible engine damage. A good, general rule of thumb is to start with the factory recommended heat range. For every 75 to 100 hp you add to your engine, you may go to the next colder step. DENSO heat ranges move up as they get colder; 16 would be our hottest Iridium Power plug, 34 would be our coldest (ranges; 16,20,22,24,27,31,34)
Q. What kind of performance will I get from this plug?
A. Generally, you do not purchase spark plugs for performance enhancement. While DENSO Iridium Power spark plugs have contributed to numerous accomplishments through dyno-testing and actual use, their true benefit lies in their efficiency, durability, and improved firing power. Serious tuners modify their vehicles by increasing boost through turbo-chargers, super-chargers, and Nitrous. They are also known to add high-energy ignition systems, tinker with timing, adjust fuel mixture ratios, and increase horsepower through other means. Putting these kinds of demands on their engine increases the need for an efficient, durable spark plug that can handle these kind of harsh environments. That’s where DENSO Iridium Power can make a major difference.
Hope this helps!
Old Aug 17, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Sorry man, I've been at work all day. Can I get a concrete price shipped to Mississauga Ontario Canada?
Old Aug 17, 2005
FALKEN's Avatar
Civicforums Junkie
are these also known as PKJ20CR-M11?
Old Aug 17, 2005
dezod's Avatar
7thgen Power Maker
Postal code?
Old Aug 17, 2005
dezod's Avatar
7thgen Power Maker
No. No where on the box.
Old Aug 17, 2005
FALKEN's Avatar
Civicforums Junkie
okay, thanks
Old Aug 17, 2005
TeLLy's Avatar
Originally Posted by dezod
Postal code?
My bad L5M7R8
Old Aug 18, 2005
sKwiD's Avatar
I Queef > You
Thanks Dezod. Information you provided convinced me to for sure get them. Boy do you know how to make a sale.
Old Aug 18, 2005
dezod's Avatar
7thgen Power Maker
Didn't try. The product sells itself with info. I just brought it to your attention.
Old Aug 18, 2005
dezod's Avatar
7thgen Power Maker
My bad L5M7R8
It's ok.
Add $7 more and it's yours at your door step.
Old Aug 18, 2005
TeLLy's Avatar
Ching ching, you've got Paypal and pm reply.
Old Aug 18, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
how about IK22's? ;P
Old Aug 18, 2005
dezod's Avatar
7thgen Power Maker
Sorry. None in stock.
Old Aug 18, 2005
sKwiD's Avatar
I Queef > You
Bought them! Thanks Dezod.
Old Aug 21, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I've had the Denso's in for probably 20,000 m and still going good, I pull them and check the periodicly. No nasty stuff on them and no check engine lights.
Old Aug 22, 2005
dezod's Avatar
7thgen Power Maker
Couple of these left. Thanks for all of the support
Old Aug 25, 2005
dezod's Avatar
7thgen Power Maker
Thanks for all of the recent support. All orders have been shipped already.
Still some left.
SimpleUser
Apr 24, 2021 02:54 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
