intercooler mister anyone?
Old Jun 14, 2003
RiceBuRNeR's Avatar
Turbo Member
Talking intercooler mister anyone?
I installed my new CF hood on my car yesterday and it doesnt have holes for the windshield squirters. So Im going to use the windshield washer tank and pump as part of my upcoming DIY intercooler mister. All I need to do is buy some tubing and a small nozle and Im set. Im going to be using my VAFC's vtec controll function in series w/ a WOT switch so that the mister only sprays when Im at WOT above 5000 RPM's.
Any sujestions on where to look for a nozle?
Old Jun 15, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
What are you gonna spray your intercooler with since there are so many things...also u might want those squirters!
Old Jun 15, 2003
RiceBuRNeR's Avatar
Turbo Member
Im just spraying the IC w/ water and the hell w/ the squirters. I never used them anyways b/c the fluid left blue stains on my car.
Old Jun 15, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
go to a junkyard and pocket the squirters from a 6thgen or something.. as for placement... i would put them right above the opening... on the underside... so u can get more pressure from the pump
Old Jun 15, 2003
RiceBuRNeR's Avatar
Turbo Member
^ that might work, but I realy need a "fogger nozle" to spray a fine mist onto the intercooler. thanks for the sujestion though.
Old Jun 15, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I know that you just want a nozzle... but this is on topic so:
Intercooler Mister System
Check this system out. It's pretty nice if you ask me.
Old Jun 15, 2003
RiceBuRNeR's Avatar
Turbo Member
Good site, thats where I got my origonal idea from.
Old Jun 15, 2003
RiceBuRNeR's Avatar
Turbo Member
Oh and I found some fine mist nozles at lowes that run off of 1/8th tubing @ low pressure. There used for cooling down outdoor areas. Im gonna buy 2 and a T fitting and try it out this weekend when I get my car back from the paint shop. If it works Ill post a DIY. Anyone else have any sujestions?
Old Jun 17, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
where do you plan on mounting everything
Old Jun 17, 2003
RiceBuRNeR's Avatar
Turbo Member
the sprayer is very small, so Im mounting it to the bumber infront of the intercooler.
Old Jun 17, 2003
ohmysac's Avatar
i'd get a little y fitting and put one on both sides...unless the fogger nozzle disperses water over the whole thing....for those of us that want to keep our windshield washer squirters where can we put a resevoir?
Old Jun 17, 2003
RiceBuRNeR's Avatar
Turbo Member
The nozle has a flat fan spray pattern, so only one is needed. Im not shure where u could put a resevoir though.
Old Jun 22, 2003
derty's Avatar
derty is an unknown quantity at this point
why not use the Pivot Water Spray Controller System
http://www.impossible-performance.cw...empcontrol.htm
Old Jun 23, 2003
Boosted2k2's Avatar
I think I'm gonna get the NX Ntercooler and use CO2. I found it at one site for $300 with a 5lb bottle... I forgot what site it was though.
Old Jul 4, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
what about if you ran a tube the length of the intercooler with jets every X amount of inches, so that when you spray the water, youd get an evenly fine mist distributed across the intercooler... ill make a pic in paint
Old Jul 4, 2003
7thgen Man-gina
heres the pic, dont know if its already been discussed or shown, if so sorry
Old Jul 4, 2003
Devst8n's Avatar
Devst8n is an unknown quantity at this point
Hey Im new to the whole forced induction ideas. This is probably dumb but I assume you are using the mister to cool the outside of the intercooler, not actually the incoming fuel charge? Has anyone thought to rewire an A/C line to help the system get really cold air through the intercooler?
Old Jul 6, 2003
Stone's Avatar
Stone is an unknown quantity at this point
running the ac would probably lose more power than its worth in cooler intake temp.
good idea though...mmmmm...in-skull wheels are turning.
Old Jul 7, 2003
MadWheel's Avatar
Premium Boosted Member
I like the tubular idea but that looks to require a good chunk of water, probable a tank to be mounted in the trunk or something. I'll try to figure out something, hey that AutoSpeed website linked above has some rediculous prices. They're selling the turbo timer I bought over $100 more in American money.
Old Jul 8, 2003
MikeAtMaxRev's Avatar
MikeAtMaxRev is an unknown quantity at this point
Go to a Subaru dealer and buy some STi intercooler spray nozzles. I have a STi and 1 nozzle mists enough to soak the stock intercooler. IMO, it really isn't a worth wile upgrade though. I live in Arizona where it has been like 115 lately and we have next to no humidity so the theory of the water sprayers should work perfectly here. In all actuality, I notice very little difference when using them.
Also, on thing that is important.... Use ONLY distilled water or you will clog your nozzles.
Old Jul 9, 2003
Devst8n's Avatar
I did some research on engines and FI and I did find that running the A/C will increase the power due to denser colder air coming in. The only difference is the power increase is related to engine horsepower. You get about a 1% increase for every 10 degrees F you cool it. With most A/C units drawing about 20-40 HP you would need and enginer 3-400 HP to make it effective. Now if only I can get my car to 400 HP then Im all set!
Supramk3
Jun 11, 2015 11:13 AM
HondaGuru
Mar 2, 2003 05:14 PM
HondaGuru
Jan 7, 2003 01:02 PM
Barney
Sep 15, 2002 04:48 PM
Barney
Sep 10, 2002 06:52 PM
