Turbo swap!
Old Sep 10, 2002
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
Turbo swap!
I took off work early today and went to the speed shop that my buddy owns. I sat down with him and had the speaker phone on and talked to Bob at turbo performance. We discssed the absolute best set up for a turbo on my 2k1civic. I gave my T3/T4 turbo and piping and intercooler to my buddy and swapped it out for a T3 turbo and 2 inch piping instead of 2.5 and an 26x6x3.5 intercooler he had. The intercooler I had was to big. Well anyways we just finished it up. It is easy just switching parts. I am still here right now. It is a smaller turbo, so less lag and smaller piping for better velocity and the right size intercooler for less lag but yet the right amount of space to cool the air. I can still get the kit for the same price but a little different parts.
I asked the guy why in the hell did you tell me to use these parts if they are not the best. He said they are the best if you want to eventually get internals. The set up I have now is so far the absolute best he said.
If you have any questions then ask away
Old Sep 10, 2002
RSXtypeIvtec's Avatar
Su Mo
how much is it for the new turbo??
Old Sep 10, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
How about some pictures?
Old Sep 10, 2002
Barney's Avatar
It is still the same price for the new set up.
Old Sep 10, 2002
ilv4nos's Avatar
ilv4nos is an unknown quantity at this point
Are you still using a 25 shot for low rpm spool?
My Civic
Old Sep 10, 2002
ilv4nos's Avatar
And how much psi can you run with the T3 despite what our motors can handle?
Thx
Old Sep 10, 2002
Barney's Avatar
You don't need it now. I still use it because I am crazy. Bob said that no one realy knows the actuall strenght of the new d17 rods, so he dosn't recomend over 60 hp than stock. He said he knows a couple of guys that have a 2k1 civic and are pushing 80-125 hp over stock and have not blown anything yet. He said the way I have it set up now is like running a 75 shot of nitrous (the way it feels) He said it should put out about 60-80 hp. I use the 25 shot the whole way through the rpm's from 1000-7000. If I blow somthing, then it gives me a reason to do internals. So I am pretty much running 105 hp over stock i guess. If I go to the dyno i am expecting AROUND 220-250 HP. Wooohoo I hope. I can't wait for internals. This single overhead will be bad ***.
Kepp in mind I am running 7-9 pounds of boost. Mainly 7
I also ordered the N-ter cooler from NX that mounts to the intercooler to keep it cooler using nitrous or co2.
Old Sep 10, 2002
Barney's Avatar
He said at a good boost level the T3 can put out about 16 pounds of boost without hurting it.
Old Sep 10, 2002
Briareos's Avatar
Briareos is an unknown quantity at this point
perhaps I missed the post, but how much was your turbo ?
Old Sep 10, 2002
Voiceofid's Avatar
End Bringer
phill, pics!?
Old Sep 10, 2002
ilv4nos's Avatar
dude you just made my day thx man...[IMG]i/expressions/beer_yum.gif[/IMG]
Old Sep 10, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
Quote
[hr]Originally posted by: APS
How about some pictures?[hr]
Here's a picture of the turbo exhaust manifold:
Old Sep 10, 2002
Barney's Avatar
Yep that the manifold I have. It depends on the turbo you use. You might have to cut and weld a new flange on the bottom end. Luckily I did not have to. Any other questions?
Old Sep 10, 2002
Desi's Avatar
Desi is an unknown quantity at this point
numberonehonda: u said that bob doesn't know the strenght of the d17 rods, is it possible to swap rods from prev. gens or get a custom rods done. i know a shop close to where i live that does works with custom rods mainly push rods but they like working on imports as well.
Old Sep 10, 2002
ilv4nos's Avatar
That manifold should bolt up to my d17a1 right?
Old Sep 10, 2002
Barney's Avatar
Yes, that manifold will bolt right on to the D17. The 1 and 4 exhaust port are the power ports for the turbo. That manifold will support a number of turbos, but if it is different just have someone weld a new flange on the bottom.
The rods from previous civics will not work in our motor. Plus they are not hardly any stonger unless you use si's. They do not match up. If you have someone who will and can do a good custom job on internals let me in on it. You can then get into the 300 hp range and plus the guy told me. He said they have a 2k1civic d17 block in there shop being rebuilt to produce 350hp. He said he has a banner over top of it saying, "whats up typre r". It means that that motor can beat or keep up with a moded type r motor. If you read some of the new import magazines it states that honda will not make the b series engines anymore. It states that the new civic, rsx, etc.. seres motors are stronger.ahahah
Old Sep 10, 2002
Simkin's Avatar
Quote
[hr]Originally posted by: NUMBERoneHONDA
Yep that the manifold I have. It depends on the turbo you use. You might have to cut and weld a new flange on the bottom end. Luckily I did not have to. Any other questions?[hr]
When you say that you may have to cut-n-weld another flange, what do you mean?
I was planning on dropping a turbonetics T3 turbo because of their ceramic ball bearings and faster spool rates. Would this case need a custom flange?
Old Sep 10, 2002
Desi's Avatar
numberonehonda: i plan on going all-motor first. but that rebuilt d17 block sounds sweet. there's a shop here in stl called rtec/lightspeed that made a custom aluminum manifold for the civics. they showed it off an hin chicago. what was different was that they made it horizontal like the previous gens. supposedly, they got 30hp on that alone. last time i heard they wanted to sell it as a product, completely bolt-on, for like $300-400. there's a pic on this website of it. they too have said d17 is very stong motor
Old Sep 10, 2002
ilv4nos's Avatar
cool just making sure this kit will fit my auto lx because its uh....slow, i probably won't be as fast as your car but i want the turbo and i will buy that along with a stall...bump my boost before launch and goodbye...thx for everything man...[IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]
Old Sep 10, 2002
Barney's Avatar
Look at the port openings into the turbo and look at the port openings from the manifold.
Manifold = perfect open square
Turbo = ?????
The port going into the turbo has to be an open square. If it is 2 rectangels or 3 or a circle, then the flange has to be changed. It is no big deal. Send it to me with return shipping fee and I will fix it for you if I have to. Or buy one from my buddy and we will have it made for you already.
The whole kit $3000
New manifold $400
Old Sep 10, 2002
Desi's Avatar
Pic of the Custom Intake Manifold
there are more pics on this site, i just haven't found them. search under hin chicago for more heres another pic
Old Sep 10, 2002
Barney's Avatar
It would be nice to get rid of our plastic one. Polished aluminum
It would look real nice.
Old Sep 10, 2002
Desi's Avatar
wouldn't a polished aluminum intake manifold be more healthier for nitrous anyway
Old Sep 10, 2002
StLVtec's Avatar
StLVtec is an unknown quantity at this point
The only bad thing about getting the custom manifold is that if u want to go turbo after that everything has to be customed. I was gonna get it done , but lightspeeed pissed me off so now im going turbo, hopefully soon I will be ordering it through you Numberone, the new one that you got. Anyways he quoted me at 650 installed and everything for it and it gives 15-20 hp, and makes are cars sound lot more powerful like DOHC ive heard it on that red car its a buddy of mine. Its just a manifold that fits D16, and B series customed onto ours.
runawaykinms
15
Mar 22, 2019 10:32 AM
Jaryn
May 17, 2016 02:52 AM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
DatGuy_Robb
Sep 3, 2015 08:08 AM
justcruzin125
Aug 11, 2015 09:09 PM
