Turbo or no Turbo that is the Q
Old Jun 11, 2003
2k2blkcivic's Avatar
2k2blkcivic is an unknown quantity at this point
Question Turbo or no Turbo that is the Q
I dunno what to do with the next big upgrade, should i do a stage 2 head and cam? which i was told is port and polish the head and the throdle body, and a new cam which is a about "50 hp", or should i go with a turbo, and if turbo, what are the different kinds of turbo and how much gain am i really going to get, in comparison with the stage 2 head and cam.
Old Jun 11, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
a cam isnt going to add 50 hp, thats for damn sure, id drop a k20 into it, 3500/4300 depends on where you get it, and then your starting out with 200hp
Old Jun 11, 2003
i'm assuming the K20 is a turbo, and where is the best place to find one?
Old Jun 11, 2003
in addition, the K20 adds 200 hp just with the kit, or do i need to mod more under the hood?
Old Jun 11, 2003
xtiszx's Avatar
Cracka
lmao, ok, a k20 is the motor out of the rsx, so you have a motor, and only the motor "stock" thats putting out 200 hp, then whatever mods you ad, you gain hp, put a turbo on the k20, and some other stuff and you would be sittin around 300 hp
Old Jun 11, 2003
yes i am a lamo, this is new to me hence "new member", and why i am asking the question. so if i buy the K20 i don't need to get mounts? its going to fit in my car, nor do i need to buy anything else?
Old Jun 11, 2003
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
youre a "lamo"?
Anyways, goto www.hasport.com and look for the 2001 civic...they have an install article and everything. you do need mounts and a lot of other stuff. But the K20A2 motor is a better platform to run a turbo off of.
Old Jun 11, 2003
lol, thanks bud, i'll check it out, and you think this is the better way to go huh?
Old Jun 11, 2003
prawdigy's Avatar
prawdigy is an unknown quantity at this point
yuppp.. the k20 would be more productive out of a 7th gen civic cuz the civic is like 100-200 lbs lighter.
Old Jun 11, 2003
well think of it this way...your stock motor turbocharged will put around 200whp (thats wheel horse power). You are basically pushing that stock motor to its limits when you turbocharge, unless of course you build up the motor, and run higher boost. But with the K20A2 motor, 200whp is easily obtained with a race header, intake, exhaust, and the Hondata ECU upgrade. With those 4 boltons, you are not pushing that engine anywhere near its limits. People with the RSX type S are running over 300whp with turbochargers on that car. There are NA kits that put it right around 280whp too.
If you want to go fast...start with a stronger motor.
Old Jun 11, 2003
true, but the new motor weighs about 100lbs pounds more than our stock motor...so it just about equals out...except that now you would have DOHC i-VTEC, and 200hp to start with...and a 6th gear.
Old Jun 11, 2003
so how much am i really looking at, the mounts cost about 650, and labor, yeah i'll take it the a$$
Old Jun 11, 2003
RedDragon333's Avatar
well worth the money IMO.
Old Jun 11, 2003
has anyone else done this on the forum?
Old Jun 11, 2003
THEANTIRICEST's Avatar
Premium Member & 1 Millionth Poster!
THEANTIRICEST has disabled reputation
yes a couple of members have.
the engine will cost anywhere from $3k-$5 depending on miles, check ebay
LOOK I searched for you
Old Jun 11, 2003
iamboo's Avatar
Retired - SoCal FI Mod
Originally posted by 2k2blkcivic
yes i am a lamo
Old Jun 11, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
just make sure u get the engine, tranny, ecu, subframe, and mounts
if you have a 2001 you will need to get a 2002+ immobilizer unit
Old Jun 11, 2003
thanks theantiricest
Old Jun 11, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
you are probably looking at around $7-9k when its all said and done. The price has really varied for alot of people.
Matt
Old Jun 11, 2003
2002+ immobilizer unit? WTF is that. I have never heard anyone talkin about that before, not even HASport.
to get the car started, you call up Acura, get a code from them for the RSX-S ECU, then that will enable you to drive it over to the Acura dealership and have them input the right code so that you can engage into VTEC. Thats it...atleast thats how HASport explained it to me over the phone.
Either that, or you can buy a Mugen ECU and just plug and play.
Old Jun 11, 2003
WannaBFast's Avatar
hasport uses a rolling computer to bypass the immobilizer unit on the 01, the 01 uses the older style immobilizer unit found in the 98-00 accord
basically to get your car started, you need to have 3 things with matching codes, the immobilizer unit, the key, and the ecu and the 2002+ rsx ecu cannot talk to the 2001 civic immobilizer unit so you have to get compatible units
Old Jun 12, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
if all you want is something that will put you into the deep 14's, then turbo your stock engine. If you want into the low 13's, build the stock engine and turbo it. if you want to go 11's or perhaps 10's, get the RSX-S engine, build it, and turbo it.
So basically if you want something to run around and pick up groceries in, and not spend $5000, just turbo the engine you have. you can find the turbo kit here for $2900.
http://www.7thgencivic.com/forums/sh...threadid=92677
But if you want to race your car, get the RSX engine.
but thats just my $.02
Old Jun 12, 2003
Ok, about the immobilizer thing with a 2001 civic...i just got off the phone with HASport, they said that if you have a 2001 civic, you dont need a 2002 immobilizer unit, Honda should be able to program it all together no matter what. He said thats just what they did initially with their 2001 civic. I asked him just to make sure "so, if i have a 2001 civic, with a 2002 motor, all i need is my keys, and the motor in the car with the stock ECU, and Honda can program it all?" he said "yes, also make sure you have the VIN number too".
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
