This is a 7th gen you don't wanna **** with!
Old May 6, 2003
  #91
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
Originally posted by SaiyanMatador
yeah our power to rate ratio is amazing, as underpowered as our cars are, they sure are light, and ill be glad to take out the interior for good and watch the lbs and numbers drop from my car soon, then and only then will it be a "dragger."
eric
wuups "Power to Weight Ratio"
Old May 7, 2003
  #92
chesireCAT's Avatar
chesireCAT is an unknown quantity at this point
power to weight
I would say power to weight ratio from a "cheap" aspect...would have to be a '92 hatch with a ls block and type r or gsr head for vtec....or from the "boosted" standpoint a '92 hatch with ls block and head boosted....we see a lot of these around my area and at Gaineville Int. Raceway....
However, I would love for my 7thgen to be fast as hell....k20
I have seen some sick sick sick turbo kits for the k20....
Can you imagine the sleeper?
Brandon
Old May 21, 2003
  #93
Sweetpants's Avatar
Sweetpants is an unknown quantity at this point
if u want power to weight...put a boosted H22 in a stripped crx
Old May 22, 2003
  #94
REDVIC's Avatar
One of few in the 13's
REDVIC is an unknown quantity at this point
Too bad it's IMPOSSIBLE to have an a turbo H22 in a Crx... Way to go champ!
Old May 22, 2003
  #95
CGodwin3103's Avatar
I Am Legend
CGodwin3103 is an unknown quantity at this point
Ok......
This got off subject.
Anyhow. I fumble with this problem to, I want an rsx swap and a turbo, and dohc. But for the 5.5k for the swap or maybe more, you can rebiuld your motor, and be able to handle more boost.
I can't decide myself, either way you will eventually have to rebiuld any motor to handle more and more boost.
So, should I get a k20, and if so, si/rsx, or rsx-s motor, with boost.
Or run the civic motor with boost and a rebiult motor... hmm...
help.
But anyway, nice ride redvic. I am jealous.
What do you think about this decision?
Running 8 psi that is great numbers, and once I have the money to do some internals, I could save for a turbo set up and get more out of it, but the question still remain.. even running 18 psi, you would probably just be hitting 350 at most. Unless you have an intake manifold, throttle body, and a cam gear and pulleys, 350 would be hard for us.
Please advise..
Old May 23, 2003
  #96
SuperNegro's Avatar
SuperNegro is an unknown quantity at this point
Too bad you're wrong, just because you cant do it doesnt mean its not possible.
Ive seen N/A H22 in CRX's and ive seen Turbocharged ones.
way to go champ
Nice car and decent install but not very scary even on 18psi
Old May 23, 2003
  #97
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
yeah, ive seen a H22 in a crx, he had to cut a hole in the hood to get it in. hey supernegro, how does 406 whp @ 18psi on a B18C1 sound?
Old May 23, 2003
  #98
SuperNegro's Avatar
heh fast, and 12's on radials 11's on slicks.
if not faster depends on the driver, clutch, axles, tires, & track conditions
Old May 23, 2003
  #99
LJ's Avatar
LJ
well, that is what that hatch put down that you and joe said couldnt break 300 hp
Old May 23, 2003
  #100
I Am Legend
I calculated it out, with your same setup, you should theoritically run 352.75 whp at 18 psi.
Assuming you can with stock interals.. otehrwise this number should be higher.. will post after i get out of work..
Old May 23, 2003
  #101
SuperNegro's Avatar
we said it wouldnt break 300hp on 8psi, get your facts straight and that it didnt
Old May 24, 2003
  #102
Chompondis's Avatar
Chompondis is an unknown quantity at this point
impressive. gotta start savin for mine...
Old May 24, 2003
  #103
REDVIC's Avatar
way to go champ
ok... In your original post you said...
-How about a Boosted H22 in a Crx...
Now how on gods earth are you going to make a street legal boosted H22 in a Crx when an H22 motor alone has to be shoe horned in??? please explain... Please! Also people tend to forget about traction! Try to get a 2000lbs Coffin on wheels to hook with an H22 alone! Are you going to drive with Slicks on the mean streets of Cali? Yet again
Old May 24, 2003
  #104
SuperNegro's Avatar
Low boost on the street high on the track with slicks.
Not every one drives like an idiot on the street trying to peel out from stop lights.
And street legal means is passes smog, has brakes and lights. Nothing too hard about that honestly.
There are plenty of sub 2000lb EG hatchbacks with H22's driving around socal and you wouldnt know it till they got on it.
and i wouldn't say it has to be shoe horned in either, and besides that, you get a custom manifold to deal with clearance issues so once again.
nice going champ
Old May 24, 2003
  #105
REDVIC's Avatar
ok BRO! listen... you CANNOT, I repeat CANNOT have a H22 in a Crx without Shoehorning the **** outta it! Now try to find enough space in to fit a turbo exhaust manifold... YOU CAN'T!!! no it's not Impossible because you can always move the firewalll back... make custom mounts... or make a tube chassis... But then the car would not be STREET LEGAL!!! get where i'm coming from??? True H22's in EG'S are not shoehorned but when did I ever said they were??? I know an H22 in a EG does quick 1/4 mile times... mid 13s to be exact but we werent talking about EG'S... we were talking about Crx's with Hella small engine bays! Alright my brotha!
Old May 24, 2003
  #106
SuperNegro's Avatar
LoL since when are mounts not street legal? or moving the firewall and actually you dont have to move the firewall back, you get a custom cross member, and place racing is working on a kit that will drop a H22 into a crx without any other work and yes turbos will fit.
Stop living in your fantasy world and come back to reality.
Old May 25, 2003
  #107
berettagtz117's Avatar
berettagtz117 is an unknown quantity at this point
where did you buy your turbo setup that is really nice if you could give me the website..
Old May 25, 2003
  #108
Drnknmnky13's Avatar
1 gallon fuel cell with a pump that puts out 300 gallons a minute? That works out to like 12 seconds worth of cooling. Or is the pump variable? Still a sweet sweet setup. But for the roughly 25k(I'm assuming 15k for the car) total you spent I personally would have bought something else. But thats just me. Great job on the chosen platform.
Old May 26, 2003
  #109
SFpower's Avatar
Former Sponsor
SFpower is an unknown quantity at this point
you will have to cut the subframes on both sides to clear the trans and the crank pullies
and to put the turbo on you have to move the ac condenser and the radiator(92/95) down and forward under the hood latch .you lose the stock strut rods put in custom rods that go
further out on the sides where thr crossmember used to bolt on .oh yea dont for get to cut the floor to lower the shifter asembly down about an inch or so to fit the cables in and keep the shifter below radio and thats just for starters
Old May 26, 2003
  #110
SuperNegro's Avatar
Just have to trim the lower frame rail on the passenger side and weld up the driver side bracket. and a custom cross member, you can use 90-93 integra axles or you can use custom.
And the shifter assembly inlet.
You also need an acuator for the hydro clutch. as for the stock sturt rods all ive seen keep them.
Old May 26, 2003
  #111
SFpower's Avatar
Former Sponsor
the integra axles i think have a differant spline an the trans. and the shift linkage on the acura is a rod not cables like the h22 and the strut rods hit the trans and the crank pulley unless you stick the motor out of the hood
Old May 26, 2003
  #112
SuperNegro's Avatar
the integra axles acutally work, for hood clearance you can get one from gude, cut the stock or get a custom one.
Old Jun 3, 2003
  #113
trashguy's Avatar
trashguy is an unknown quantity at this point
I have a Datsun 510 that could smoke it :-) but I like that set up a lot... where did you get that Liquid intercooler from?
Old Jun 3, 2003
  #114
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
looks like a vortech aftercooler
Old Jun 4, 2003
  #115
RiceBuRNeR's Avatar
Turbo Member
That has to be the cleanest setup Ive ever seen.
rhyno
Nov 29, 2001 12:12 AM
KOPSEAL
Nov 25, 2001 12:24 AM
brill
Nov 12, 2001 07:29 PM
TropiKalCiviC
Nov 8, 2001 10:13 PM
colombianDXcivic
Nov 7, 2001 09:45 PM
