Complete D17A 8lb Turbo setup for under 2600$ ?
Old Apr 17, 2003
  #31
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Originally posted by 4bangin
i think he means flywheel horsepower.
yes... fwhp=flywheel horsepower
Old Apr 23, 2003
  #32
RedDragon333's Avatar
Originally posted by Catalyst
Extra injectors? Isn't that the cheap, easy, and somewhat inconsistent way of doing a fuel system?
Stafford Fab. has the only real way of doing a fuel system for these cars, and it doesnt require a return line likle most people think. And it doesnt need a new fuel rail, new injectors, or anything. Works with all stock parts.
How hard is it to install your fuel kit? is it easier than 3 wires, a fuel in and fuel out?
yes but for those of us that have the EX SF isnt doing jack for us so we had to look elsewhere. So far this seems like a pretty good setup.
Old Apr 24, 2003
  #33
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
SFpower is making one for the EX. the only difference is the downpipe. If you guys want it that bad, just buy the LX kit, and have a muffler shop modify your exhaust to work. it isnt that much of a difference. I work at a muffler shop and we would charge someone $30 to do the modification.
Old Apr 24, 2003
  #34
dragoon's Avatar
Originally posted by PbFoot
you'd still need to make your fuel system so its not returnless, so thats added costs.
and im sure if you get an intake manifold made thats gonna increase your gain even more. just something to think about.
RSX and protege5 also have returnless systems, and most turbo kits for those cars do not come with a fuel return line. same with the ones that are coming out for 7th gens. i don't see a return line in the list of components, but i do see additional injectors, fuel rails, and other things to increase the amount of fuel that can be supplied to the engine.
Old Apr 24, 2003
  #35
Catalyst's Avatar
if you do what turbo performance says and add RSX infectors/fuel pump/fuelrail, you will run rich as hell all the time, and then you will only be good for about 5 psi of boost at max.
Old Apr 24, 2003
  #36
ImportRacer2123's Avatar
K20 Member
Can i see a show of hands of who is going to buy the Custom Turbo from Turbo Discounters for the EX? Because im really thinking of buying this one. Catalyst how much is the Turbo kit your selling going to run?
Old Apr 24, 2003
  #37
dragoon's Avatar
what if you add a AFC or something similar to manage the a/f ratio? wouldn't that result in more overall potential in the end?
Old Apr 25, 2003
  #38
Catalyst's Avatar
i read on the Apex website that the SAFC will not work with our cars. They said that if you bought one, you shouldnt install it until they can figure out the problem and fix it.
Old Apr 28, 2003
  #39
AvrilLavigne45's Avatar
AvrilLavigne45 is an unknown quantity at this point
what about the Ex model i want a turbo
Old Apr 28, 2003
  #40
Catalyst's Avatar
SFpower is making a turbo for the EX. The ONLY difference between the LX and EX turbo kits, is the length of the downpipe. The LX has a longer downpipe. That is it. The ONLY difference.
Old Apr 28, 2003
  #41
K20 Member
Catalyst Could break down everything that is included in the kit your making and how much it's going to cost?
Old Apr 28, 2003
  #42
mike0404's Avatar
mike0404 is an unknown quantity at this point
I have apex safc on my lx and it works...i got like 6 hp to the wheel when they dyno tuned my safc...
Old Apr 28, 2003
  #43
Catalyst's Avatar
Mike...Maybe i should read that article again.....
import... The kit comes with....
Garrett T3 (internal Wastegate)
Custom 4-1 exhaust manifold
custom 2 1/2" downpipe
custom intercooler
Custom intercooler piping
Custom Blow off valve
check valve (like a missing link)
Fuel kit (does NOT need any injectors, rails, etc.)
Hose clamps and couplers
Oil Lines and fittings
oil drain line (must be welded into pan)
Bleed valve (to control boost)
and a CD with instructions and videos on how to install it.
Old Apr 28, 2003
  #44
Catalyst's Avatar
oh yea, you can get the kit tomorrow for $2900
Old Apr 28, 2003
  #45
Catalyst's Avatar
look for it in the group buy section
Old Apr 29, 2003
  #46
K20 Member
Will you by any chance have a turbo kit in June? Because i can't come down to California until after June 6th. Graduation but i will have the money for it i can assure you this.
Old Apr 29, 2003
  #47
Catalyst's Avatar
SFpower is going to send the kits out in the mail. He is waiting to post the group buy because he has to register for that vender membership thing. As soon as he pays for that, he will post the group buy.
Old Apr 30, 2003
  #48
K20 Member
So no pick up?
Old Apr 30, 2003
  #49
Catalyst's Avatar
you can pick it up if you want to.
Old Apr 30, 2003
  #50
K20 Member
Cool I will come pick it up in June
Old May 2, 2003
  #51
mike0404's Avatar
new update..turbo kit is now available You asked to be notified when we started selling D17A turbos, they are now
available here:
http://www.TurboDiscounters.com/html/Turbo-Honda.aspx
The Extreme kit is $3,120, the Superior kit is $2,100. Both kits come with
the new Garrett T25 Dual Ball Bearing turbo!
Check out our site for more info.
TurboDiscounters.com +>
(800) 861-0691 - http://TurboDiscounters.com
Old May 2, 2003
  #52
azure's Avatar
Cool! Yeah, I got the e-mail from Turbo Discounters too.
Old May 3, 2003
  #53
mike0404's Avatar
now i need is $ 5K
Old May 3, 2003
  #54
Catalyst's Avatar
wow, a t-25. yippee [end sarcasm]
Old May 3, 2003
  #55
derty's Avatar
derty is an unknown quantity at this point
catalyst why do you knock so hard on turbo discounters turbo kit? I would like to know what you know. Maybe compare your turbo kit with theirs and let everyone know the differences between them ^^ to help people decided which kit to invest in.
Old May 3, 2003
  #56
Catalyst's Avatar
well, the first thing is the T25. If you ever want to make more than a 250 whp max, you cant use a T25 because they wont flow enough CFM of air. You can only make about 250 whp when you port the entire turbo out.
They use a cast log style manifold. Sf's is a 4-1 hand made one.
They use extra injectors, SF's uses the stock injectors
They say they have a 56% increase on any car (nissan, toyota, mazda)
Well, with this fuel system, header and turbo setup, SF's kit layed down almost 350 whp on a CRX. They get their HP increases by using the (somewhat true) hp * atm = powergain equation. Theoretically, if you run 8 psi of boost, you should gain around 56% hp at sea level. BUT, what they dont bring in is the density factor, and the heat factor. If you run 8 psi on a hot day, you will make MUCH MUCH less than on a cold day. and when you are at sea level, the air is more dense, which means every pound of boost is actually more effective because there is more air in the charge. And when you compress air, you create heat. The intercooler helps with this heat, but it does not bring the heat down as far as you need to generate that 56% increase. They should dyno test their kit on a completely stock car and then post the numbers. Not take their gains from some damn equation which doesnt take heat and density into account.
I am sure that this kit will work, and you will gain some horsepower...
But I doubt that you will gain 56% without running more boost, and with that log style manifold, the spool up time for that T25 will be about the same as my T3.
Old May 3, 2003
  #57
Catalyst's Avatar
I am not just saying this out of my A$$, i do this to the greddy kits and DRAG kits and Revhard kits for the earlier civics. The reason SF is making these kits is because of the complete lack of quality kits for the every day guy. He is giving everyone a hand made kit, for $200 less than the mass produced, stamped out stuff that you can get from these other guys.
Also, i am not part of SF's company, so dont yell at him for my opinions. I am just a 4 time customer of his turbo kits, and i know the difference between all of these parts by experiance.
Old May 3, 2003
  #58
derty's Avatar
thanks catalyst that clears up my mind ^^ lol maybe soon i'll be down by his shop -=]
Old May 3, 2003
  #59
SFpower's Avatar
Former Sponsor
SFpower is an unknown quantity at this point
if you look at the parts list you'll notice that thier down pipe dosn't fit the ex or the lx.
at least my kit comes with a down pipe that fits an lx and you can easily modify your ex exh. until i get an ex in the shop to install my system andbuild a completly new header to make it work with the stock ex exh. any volinters???
Old May 3, 2003
  #60
JoNnNnY's Avatar
JoNnNnY is an unknown quantity at this point
available here:
time to start saving
Jon
