swaps 7 th gen
Re: R18 ECU swap for D17?
No, the only "easy" swap you can do is a k. Everything else is either illegal (emissions) or requires tons of custom fab work, or both
You would need to do some clearance-ing. And aftermarket mounts. Easiest is to buy a wrecked/rotted RSX and then everything is bolt in, subframe, suspension, etc. Just need to remove one engine bay mount from the RSX and spot weld it into the civic engine bay
start from the stickies on the top of the page.
here is one:
https://www.civicforums.com/forums/7...-swap-faq.html
here is one:
xtremedreams
Dec 10, 2002 08:02 AM
