Possible to swap r18a into d17a?
Old Jun 6, 2019
Holdfast's Avatar
Holdfast is an unknown quantity at this point
Hi group!
My 2010 Civic was wrecked the other day, and I have been looking for an inexpensive Civic to put the Engine/Transmission into. R18a automatic trans.
i found a 2005 Civic with a blown head—d17a—and wondered if this was a direct fit, or problematic choice?
So, an 8th gen into a 7th gen..
Thank you!
Holdfast
Old Jun 6, 2019
Colin42's Avatar
Re: Possible to swap r18a into d17a?
not going to work without a lot of custom fab work and headaches.
find an 8th gen with a blown engine, shouldn't be too hard
Old Jun 6, 2019
Holdfast's Avatar
Thank you Colin42. I will start looking!
Old Jun 12, 2019
mac25's Avatar
Dr Krieger of Modification
D17 has a mechanical cable driven throttle body. R18 is drive by wire, electronically governed. Meaning that the R18 ecu is expecting to position the throttle /read the TPS. I doubt it would be very happy with no communication to the throttle body.
Old Jun 12, 2019
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Possible? Yes. However, as previously stated, it would be a lot of work and quite expensive because a lot of custom parts would be needed. You would be better off finding an 8th gen with a blown engine and putting your engine in. Hope this helps
Old Jun 14, 2019
Holdfast's Avatar
Thank you. I have been looking for an 8th gen and the only one I found is over 300 miles away. So not to many around—I’m in a rural area. I did find an 8th gen Hybrid, but that is probably not an option.
thanks again!
Old Jun 14, 2019
thanks again!
A hybrid is definitely not an option for a quick and easy swap. If you still have your donor car and you don't mind a very long project swapping everything over to make it work (subframe, mounts, lots of wiring, ECU, radiator, hoses, gauge cluster, shifter, AC lines, etc) then you should be able to make it work with not much more than the parts you have on your wrecked car, but it will be a lot of work and very time consuming. It would take a lot more time and work than it would be worth IMO.
However, depending on how badly your car is wrecked, you could possibly buy the hybrid as a donor to fix your car if you still have it. Hope this helps
Old Jun 15, 2019
Holdfast's Avatar
Yes, I had thought it would be difficult—even without knowing everything you listed. I will keep looking for a direct swap. Sent a message to the one person I found selling a 8th gen, with a wrecked motor, but have not heard back.
Thank you again!
Old Sep 24, 2022
Rubik's Avatar
New Member
Rubik is an unknown quantity at this point
how about r18 tranny on a d17 engine, would it work? Thanks in advance
Old Sep 24, 2022
Colin42's Avatar
No......
just put the proper tranny in
Old Sep 24, 2022
Rubik's Avatar
New Member
Originally Posted by Colin42
No......
thanks man
Old Sep 24, 2022
Rubik's Avatar
New Member
No......
thanks man
lorne17
Apr 28, 2012 03:46 PM
solo_rider
18
Sep 26, 2004 07:22 PM
anotherlevel
27
Jan 27, 2004 12:03 AM
mclean987
Bolt-on Engine Performance
Sep 17, 2003 08:11 PM
MyOtherRideIsBritney
Jan 1, 2002 12:58 PM
