2015si engine and tranny in a 2005 ex se will it work?
Old Mar 31, 2019
newbytuner's Avatar
newbytuner is an unknown quantity at this point
Just wondering if it's at all possible to swap the 2015 si into a 2005 ex. I know it would take a lot of work if it's possible.
Old Mar 31, 2019
Colin42's Avatar
Re: 2015si engine and tranny in a 2005 ex se will it work?
Unless you have lots of fab skills no, plus the computer is going to freak out because it's not going to see everything that it's used to seeing. Much better off to use parts from an rsx
Old Mar 31, 2019
newbytuner's Avatar
What year rsx would be best to get a motor and everything from?
Old Mar 31, 2019
Colin42's Avatar
05/06 try to get the whole car if you can, then you know you have all the parts. Plus you can swap over the suspension and hubs to do a 5 bolt conversion
Old Apr 1, 2019
newbytuner's Avatar
I was thinking trying to find one that was totaled out and using it to do it. That the best way to do it?
Old Apr 1, 2019
Colin42's Avatar
pretty much just make sure any parts that you use aren't damaged
Old Apr 1, 2019
newbytuner's Avatar
Is it hard to swap a k20? I've never swapped an engine but I am mechanically inclined. I believe I could do it myself I'm trying to keep from paying a butt load for labor.
Old Apr 1, 2019
Colin42's Avatar
not terrible, there's a thread on here where a guy k swapped with an auto trans, had lots of pictures and explanations. can't find the thread at the moment.
everything lines up besides one engine or trans mount you need to move to the other side of the car and re spot weld it
or you spend a ton of money and get the aftermarket mount kit.
Old Apr 1, 2019
Colin42's Avatar
found the thread
https://www.civicforums.com/forums/7...swap-auto.html
f8fulcvk
Apr 6, 2011 05:51 AM
DJ GEE
Sep 20, 2006 10:20 PM
K/Turbo
May 2, 2006 01:33 AM
02ciVike
Engine Swaps
16
Oct 29, 2004 07:20 PM
dalaw
Aug 27, 2004 07:46 PM
