Transmission Swap Question
Old Aug 29, 2012
JJ291's Avatar
No amateur/no professional
JJ291 is an unknown quantity at this point
2001 Civic LX - D17A1
Doing my first transmission swap. Is it better to lift the engine and transmission out as one piece with an engine hoist, or follow the service manual and go out the bottom with an engine support bar and a transmission jack? I inspected option 1 (both out the top) and it looks like it could just barely fit if it was turned at a slight angle...
Any experienced help in this would be much appreciated. Thanks.
Old Aug 30, 2012
marek91's Avatar
marek91 is an unknown quantity at this point
Re: Transmission Swap Question
I have always dropped the tranny out of the bottom on all my civics but I know people who swear by lifting the motor and tranny out of the top together. either way would work.
Old Aug 31, 2012
JJ291's Avatar
I appreciate the reply - it really helped me. I decided to to take it out the top just because I'm going to do the mounts and timing belt and a few other things while it's out. Excited but nervous...next Thursday is the big day.
Old Sep 2, 2012
dookietwo's Avatar
dookietwo is an unknown quantity at this point
Are you doing a AT to MT?
May the force be with you.
Old Sep 3, 2012
JJ291's Avatar
No - probably should though! Actually, I found a pretty good posting of what I'm in for...
http://imageshack.us/f/17/dsc05657p.jpg/
Has to come out at a 30 degree angle since it's 1" too wide for the body (thanks, Honda). I plan to take more off than that guy did, though.
It's seems ironic to me - I've never done anything this significant to a car but it seems like the hard stuff would be parts, mechanical connections, etc. However, I'm finding that getting advice on lifting points, etc. seems to be a mystery. I'm trying to follow the service manual closely - I'm actually taking an industrial hinge (x2) and modifying it to match the lifting bracket in the manual...overkill? Probably.
Old Sep 15, 2012
j_dock69's Avatar
j_dock69 will become famous soon enough
Make sure you use good bolts for the hoist and try not to strip them. Make sure to remove pwr steering pump, alt, and ac compressor. I usually just pull my trans out the bottom. I'll be doing it again here soon, my second gear synchro is gone
thesushiboy
Jun 4, 2015 03:03 PM
zack22490
Apr 29, 2015 03:17 PM
Rinzlor
Apr 24, 2015 10:33 AM
viper775
Dec 9, 2001 10:52 PM
supercivic01
South
Nov 30, 2001 11:27 AM
