Headers Question
Old Aug 19, 2012
haidar6's Avatar
haidar6 is an unknown quantity at this point
Headers Question
hey i need help, i have a 2005 honda civic lx 1.7L and im trying to change my stock headers into aftermarket header, i was wondering if an 04 civic ex aftermarket header would fit on my 05 civic lx?
Old Aug 19, 2012
palsana's Avatar
palsana is an unknown quantity at this point
Re: Headers Question
do you have pic of header!!!!!
Old Aug 19, 2012
Technically, yes, it'll fit. It'll bolt up to the was just fine. The problem lies on the other side of the manifold. Since your cat is integrated I to your exhaust mani, and the ex has it as part of the downpipe, your manifold is longer than an ex's. you'd have to convert to an ex exhaust setup
Old Aug 22, 2012
aircooledjames's Avatar
aircooledjames is an unknown quantity at this point
It will fit, but you are going to have to buy a new cat and have it welded onto the exhaust. You will also have to purchase an 02 sensor extension cable. BE VERY CAREFUL as you drive an 04 and it runs a wide-band sensor which is VERY expensive to replace. I learned the hard way. i bought an after market header with cat delete. the sensor was pushed out and the wiring to the sensor arched and fried not only my stock sensor but ruined my ECU. i had to put it back to stock, and buy a new sensor ($250ish) and new ECU($600 new, $150ish used). You won't see huge gains running a header on this engine and you'll lose A LOT of low end torque.
bhollie
Aug 19, 2015 01:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
