j swap
Old Oct 3, 2011
cmiller_01ex's Avatar
cmiller_01ex has a spectacular aura aboutcmiller_01ex has a spectacular aura about
j swap
im thinkin about swapin a j into my car. so help? lol any would be good. i just wanna know what im gettin into. and custom fab aint nothin.
Old Oct 3, 2011
MindBomber's Avatar
Live for the Twisties
Re: j swap
Being the first to do a swap has a certain amount of prestige, but it'll be a lot of work..
custom mounts,
figuring out the subframe,
what axles and knuckles to use,
custom exhaust,
dealing with the hood clearance,
you need to work out all the wiring.
Old Oct 4, 2011
Re: j swap
now if i do go ahead and attemp this will i get support here? cause im sure guys here know more about wiring than i do. and with the hood clearance. ive seen the body style befor ours fit one with out cutting a hole. they just got ride of all the framing under it. i figure this way its cheaper, cooler, more custom, and faster. and with the axels there si a company that makes them for earlier model civics, they should fit right? or do you think the earlier civics are a little narrower? thanks man for the help already. oh and with the wiring. if i get the accords wire harness chop it and figure out what wires do what i should in turn be able to hook them up with my harness right? or am i completely wrong? sorry for all the questions. but dude your like the civic forum god lol
Old Oct 4, 2011
MindBomber's Avatar
Re: j swap
The earlier generations do remove the subframe and I see no reason why you couldn't do the same, you just need to factor that in when your making the custom mounts.
I believe the earlier gens are narrower and so few people have done this swap on later generations it's hard to tell you what you'll need, I think you might be able to use DC5-S axles.
Yup, that's how the wiring would work. You just need to get the wiring diagrams for both cars.
The guys on k20a.org, they'll have more answers than I do on this subject.
http://www.k20a.org/forum/forumdisplay.php?f=136
It sounds like your off to a good start with your research, good luck, I'd love to see this actually happen.
Old Oct 5, 2011
sl33pyriceboi's Avatar
Re: j swap
its doable, but its a REALLY big engine. ur going to have to do a LOT of custom fabrication (wiring should not even be a concern yet. the frab should be)
go for it. but u should be expecting to spend $10,000+
first things first, can you weld? tig and mig?
Old Oct 5, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: j swap
The only problem I see, is that the engine is too large, you'd either have to decide to risk bottoming out your oil pan, or cutting the hood
I really wish you the best of luck here, and possibly start a build thread so that others interested can learn too
Old Oct 5, 2011
Re: j swap
ill def make a build thread but its gonna be a while and i cant see this swap being around 10000. cause the j motors aint that exspencive. matter a fact i can get the engine and tranny from a local junk yard for under 500 then i can see about another 500 in metal for fabing. the wire harness is around 30 from the same car. and i'll get another from my civic so i dont have to cut mine up. then after that axels are gonna be exspencive but mooser custom builds axels and they quoted me 170 to shorten and have my axels swapped from ford 5 lug to chevy 6 so i cant see having the accords shortened and swapped being much more. so im sure i can have it for under 5000
Old Oct 5, 2011
Kenny the Ricer
Re: j swap
The biggest killer on these kinda swaps is the custom fabrication involved.
Old Oct 5, 2011
Re: j swap
lol i know. but im swapping a 302 into a mazda b2200 as we speak. its got custom mods involved too because i aint buying the kit for it. that and i do mini's and i got a few buddys doing mini's we aint afraid to do anything. and if i cant weld it they can. but like i said it'll be a little while because right now im in the route to join the air force. but if ya'll find anything that looks like it could help me please do let me know.lol
Old Oct 5, 2011
Re: j swap
Keep ya updated. Anything is possible. The j series has gone into CRXs before so it's possible
Old Oct 5, 2011
Re: j swap
y'all kidding, right?
they already have mounts made, 2 types
http://www.hondatuningmagazine.com/t...aps/index.html
Old Oct 5, 2011
MindBomber's Avatar
Re: j swap
It can be done for $5000-7000 if you're not paying someone to figure out the wiring and fabricate everything for you. Remember, the cibaru only cost $5k total to build.
Old Oct 5, 2011
Re: j swap
but those arent for our 7thgens are they?
Old Oct 5, 2011
Re: j swap
thanks for the input guys. i'll def start grabing things as i find them seeing this is going to be a long term build. i wanna get in the airforce and get a new dd before i start this work.lol
Old Oct 6, 2011
Re: j swap
yeowps...
true - i heard that they had for 7th, but i could be mistaken (or the guy who said might have been :P)
edit: just looked at their site, no mounts for 7th gen
Old Oct 6, 2011
MindBomber's Avatar
Re: j swap
There's only one other person seriously considering a 7th gen j-swap that I've heard of and he changes his mind about his build plans weekly. First it was K, then J, then J was to expensive so back to K, then J was worth the expense, now a turbo D sounds cool.. not going to happen..
Old Oct 6, 2011
Re: j swap
lol damn that sounds like me. but i think the j is worth it every one is doing k's or turboin d's so i wanna do a j and maybe one day turbo the j. but today im makin a trip to the yard to maybe score a ecu and wire harness. and an imobilizer ring.lol with that should i just take the whole ignition?
Old Oct 6, 2011
MindBomber's Avatar
Re: j swap
I don't know how well the j series ignition would connect to our stock parts, I'd take the whole thing.
Old Oct 6, 2011
Kenny the Ricer
Re: j swap
I really hope you start this project
My buddy bought a 1990 miata as a project car, going into the air force
...3 years later, the car is still untouched :P
He claims he just doesn't have the time to do anything to it (Though he has the resources on base)
Old Oct 6, 2011
Re: j swap
lol yea im prob gonna do that but teh only 3.2 motors our junk yard has is out of a acura legend... they are a bit older than my car so it wouldnt be street legal... and those motors are huge!!!!lol
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
