What parts are necessary to achieve 250-300whp.
Old Sep 15, 2011
  #31
killa121's Avatar
rookie enthusiast
killa121 is an unknown quantity at this point
Re: What parts are necessary to achieve 250-300whp.
would 770 shipped be a "decent" price for this?
Wiseco forged pistons pn K624M75 – one set (4 Ea) of 75mm turbo pistons, rings, wrist pins and locks.
K1 Technologies H-beam rods pn HH5394ACAB4-A one set (4 Ea) of connecting rods balanced to within 2 grams, and ARP 2000 rod bolts.
Old Sep 15, 2011
  #32
killa121's Avatar
rookie enthusiast
as far as the spun rod bearing just about everything should be replaced. i have a friend whos actually in school for machining now so maaaaybe i can get a hook up. i took your info into consideration though and tried finding a bare, for sure sturdy, bottom and no luck : /
Old Sep 15, 2011
  #33
MindBomber's Avatar
Live for the Twisties
If your feeling confident..
You could probably pick up a cheap D16 crank in good shape for a steal, since many more 6th gen civics are being parted and build a destroked d17. It can and has been done.
Old Sep 15, 2011
  #34
killa121's Avatar
rookie enthusiast
Is there any gains to using the d16crank? Or is it the same but much easier to find/afford.
I'm sorry to show my nubness but I don't understand what stroked and destroked means...
Old Sep 15, 2011
  #35
MindBomber's Avatar
Read this thread when you have time, it should answer all the basic questions about a destroked d17. A d16 crank is definitely less difficult to find and likely less expensive.
https://www.civicforums.com/forums/7...questions.html
Old Sep 16, 2011
  #36
killa121's Avatar
rookie enthusiast
This was a good question.
" The question I would likeanswered,is would higher RPMs(1.6L) with the same turbo as the non-destroked engine ultimatlyproduce more power, since the number of RPMs would (i guess?)pack more airflow "time"than the2.0Lwould atlessRPMs.Or would it equalize?"
And how do you find and gauge the new ratio of rpm?
And untimately what's the point??
** didn't want to bump a thread from 03
mohawkboom
67
Aug 25, 2015 12:28 AM
Tim1959
Jun 3, 2015 08:15 PM
juror
May 26, 2015 06:35 PM
shindrome
Exterior
May 5, 2015 02:50 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
