How do I know if my ECU has been modified?
Old Dec 24, 2010
boosted01civic's Avatar
boosted01civic will become famous soon enough
Ok guys I have a question that may be stupid. I bought my car turbo'd and I am getting ready to install the AEM F/IC on it and looked at teh ECU more closely tonight and noticed that there has been some repinning done to it and I noticed that there are some wires labeled injectors and one labeled throttle body. So how do I check to see if it is stock inside?
Old Dec 25, 2010
mac25's Avatar
Dr Krieger of Modification
Re: How do I know if my ECU has been modified?
post pictures please. sounds like the stock ecu is there and they ripped out a piggyback, but it's hard to say without seeing anything.
Old Dec 25, 2010
I will. So I pulled the ECU out and it has obviously been tampered with. There was a notch cut into the back side of the ECU but nothing in the notch. The wiring issue appears to be where wires were just located. there have been numerous hack wiring jobs that I have found on this car and to be honest this scares the sh*t out of me with the ECU. Any way to test it to see if there has been anything messed with?
Old Dec 25, 2010
[IMG]file:///C:/Users/Kris/Downloads/70.jpeg[/IMG][IMG]file:///C:/Users/Kris/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Kris/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
ID:	79874   Click image for larger version
Old Dec 25, 2010
MindBomber's Avatar
Live for the Twisties
Sometimes you need to cut a hole in the ECU to run a USB cable or something like that to plug in...
Old Dec 26, 2010
yeah but the d17 ecu can not be used for Kpro so what would they have needed a usb port for? should I just buy another? If anybody has a d17 manual ecu p/m me.
Old Dec 26, 2010
MindBomber's Avatar
Just because it can't be used for Kpro, doesn't mean that they didn't have it hooked up to a dyno or another system.
Old Dec 27, 2010
a turbo will require changes in the ECU if not running any aftermarket.
i would be scared if there was no changes actually.
Old Dec 27, 2010
I think they had an aftermarket piggy back on it and yanked it out. Other than kpro there isn't a need to notch that particular ecu according to the guy at the performance shop. As long as its not messed up I dont think it matters. It will have an AEM F/IC on it in the next couple of days.
Old Dec 27, 2010
then i would guess the PO did keep the k-pro to himself (1k and all)
Old Dec 28, 2010
mac25's Avatar
you could check to see if it has a hondata s100 or s200, if so i don't think you need the fi/c. the two mentioned above "Fits inside the ECU. No external wiring" and look like this.
you do need to cut a hole for a usb cable inorder to tune. the stock ecu is untunable without such modification. so there is a good chance a chip like this one is in there. find ut because they're worth a good bit of money. i was going to get one but they don't work for autos.
Old Dec 28, 2010
MindBomber's Avatar
The problem with modified cars is that people do weird **** to them.
The guy at the performance shop is right, there is no point in cutting a hole for a usb cable in an untunable ECU, but that doesnt mean some genius didnt buy one of those fake performance chips off ebay or something like that.
Old Dec 30, 2010
yeah the previous owner of this thing is far from a genius. I have never seen so much hack job wiring on one vehicle in my life. They used a home phone line to wire the gauge pod because it had enough wires inside to hook up all the gauges-too bad it caught on fire from not being able to handle the voltage, and an extension cord to wire the oil pressure gauge.
Old Dec 30, 2010
MindBomber's Avatar
Wtf...
Old Dec 30, 2010
exactly. I have had my hands full
Old Dec 30, 2010
Stock 99's Avatar
Wow
In all fairness the extension cord wire is probably a heavier gauge then what you need, but still.
Has that black IC chip been installed by someone? Is that what your pointing out in the original picture? That looks similar to 'chrome' tuning. Burn the chip on the PC and install into the ECU.
I wish I had the code for that modchip that mac25 pictured. The raw product is worth about $4 and I own a PIC progammer
edit - oh I see your just pointing out the hole. I wish I could figure out how to delete my dumb posts.
sorry boys
Old Dec 31, 2010
OMG, the PO did a whack job in the car and thought it was a good turbo setup...
good luck...
yes, if that is the job they did, recommend a new ECU...
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ken4444
Sep 30, 2015 07:37 PM
ttamrekab
Sep 28, 2015 01:22 AM
Dave Brabant
Sep 27, 2015 09:43 PM
260000milesgoal
Sep 25, 2015 07:41 PM
