Spark Plug Heat Ranges
Old Jan 25, 2010
2k5reverb's Avatar
2k5reverb will become famous soon enough
Hey guys i was just wondering what plugs you recomend using for a turbo application. I have been told i should go a heat range lower than stock. Just wondering what your using?
Old Jan 25, 2010
Re: Spark Plug Heat Ranges
usually one heat range lower is good for highly modded car nos/turbo/sc. depends on your driving tho. if you stay out of boost alot, stock range may be enough. you have to really test and see by checking the plugs every so often and you can tell if theyre overheating or not getting hot enough. i would say try stock first, and then pull them out and see what happened. stick with cheap copper ngk or denso plugs so you arent wasting alot of $$.
mistermenphis22
Jul 13, 2015 04:43 PM
stvpagn
Jul 9, 2015 09:59 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
