Y8 mani ON the D17
Old Jan 26, 2009
  #31
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Y8 mani ON the D17
For the TPS you just swap the plug to the d16 plug keeping the wires in the same order as the d17. The d17 IACV plugs fits directly into the IACV on the automatic d16 (it might work with the manual one too, I just don't know). For the map I used a short (like 3") section of 3/8 rubber hose, jammed the map into it and clamped the hose with these things that look like t-bolts but they are tiny sized (autozone ~$5) and stuck the other end of the hose on the top vac port on the front of the mani and clamped that end too. Its a little ghetto, but it works and I didn't have to extend the wires. Its getting swapped very shortly for an AEM MAP though because the stocker only reads about 11 psi.
Old Jan 26, 2009
  #32
01_EM2's Avatar
01_EM2 can only hope to improve
yeayeah i found some one with a y8 tb from an auto. they bought the motor and had to use the manualy8 tb cuz the iacv pllug didnt fit.... just what the doctor ordered
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
SammySC
121
Apr 7, 2017 07:43 PM
solarpunk70
Apr 12, 2016 11:43 AM
sccarally
Texas
Sep 27, 2015 03:33 PM
