Car runs lean now after being boosted w/ emanage
Old Nov 9, 2008
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
SO yeah i was turboed for the summer and fall with emanage.
I put car back to stock and now when I start my car it will start up fine but then when I go to drive it it like goes right to lean when I give it gas. I can push peddle down to floor and like nothing happens, my wideband shows lean all the way to end. But if i restart car it works fine.
I don't get it
Is my ecu messed up?
Old Nov 9, 2008
Krieger's Avatar
Krieger is an unknown quantity at this point
Re: Car runs lean now after being boosted w/ emanage
idk. the e/manage was just a piggy back so it should have reversed itself...
why did u install the turbo?
btw, u selling it? lol
Old Nov 11, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Well our engines do run a tad lean to achieve good fuel mpg...What type of afr gauge are you using? A wideband or narrow?......I don't know how lean your gauge is showing but if the car is driving fine I wouldn't worry about it. Check the plugs and make sure it is not very very lean or denotating.
Possibly try to reset ecu and perform idle relearn aswell.....
It is also possible to use the cars 02 sensor readings to determine afr...if you have access to a scan tool with on the fly data......new hondas w/ wideband sensors read afr's exact. Yours will probably be a voltage you will need to reference to see what is acceptable. Then you can compare readings.
drjvic04
Bolt-on Engine Performance
Apr 7, 2005 09:49 AM
RoBBUsaF
Engine Swaps
May 9, 2004 04:14 PM
ricergribbs
Feb 25, 2004 09:40 PM
ricergribbs
Engine Swaps
22
Feb 25, 2004 04:54 PM
wannabeblown
Jan 11, 2004 01:43 AM
