Map voltages
I got my emanage to hold a steady green light. I have the exact ssame settings as opto does. The only differences between our cars is that his map voltages are different from mine. His reads at 1v/1v at idle whereas mine reads at 1.8v/1.8v idle causing my engine to stall when gas is applied. His engine is happy. My activity light has a steady green light.
However, when I take my emanage out of the equation and run the stock ecu, my car is happy when i tap the gas and does not stall.
1. Is this due to the fact that my engine is built?
2. If it was a bad map sensor then wouldn't my car act up using stock ecu?
3. Does the emanage just need to be tuned/tweaked?
Thanks in advance for any help.
why don't u just take it to a shop and get it tunded then problem solve. Then you'll find out if the cause of it is the fact that ur engine is built.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
Bricoleur
Sep 9, 2015 12:23 PM
