help: replacing head gasket
Old Jul 27, 2008
  #61
civcspool's Avatar
civcspool will become famous soon enoughcivcspool will become famous soon enough
Re: help: replacing head gasket
Thank you for the help rep++
Ok i just bought Aem FIC with boomslang harness I'm just waiting for it to arrive. question is can i use LX ECU +AEM FIC to control the vtec solenoid straight from the FIC ? and control the 2 extra injectors from tsi ?
Old Jul 27, 2008
  #62
speedfoos's Avatar
You're welcome, but you've just gotta let the TSI thing go. As soon as the FIC arrives, throw away the TSI injectors and install your RSX injectors. Although the F/IC can control 6 injectors, you're asking for trouble trying to wire in the TSI injectors, plus you won't need them with your RSX injectors.
The FIC doesn't control a VTEC solenoid either so you will still need to run a VAFC, EX ECU, or something else to control the VTEC solenoid. I guess the only other option to that would be to run an RPM window switch to the VTEC solenoid so you could have the solenoid engage at a certain RPM. While this is not ideal, it would work. Basically it would be a homebrew VAFC that allows engages the VTEC at a set RPM. You would just need to figure out the voltage the solenoid needs to engage, wire it in, and you now have complete control over your VTEC engagement. These switches can be had for anywhere from $50-120. If you're at all handy with electronics, it wouldn't be that hard to wire in.
Here's a nice MSD one.
MSD RPM switch from Jeg's
Old Jul 27, 2008
  #63
civcspool's Avatar
I think im gonna go with ex head + vafc2 to control the vtec + lx ECU + FIC to control the injectors
is that fine?
Old Jul 27, 2008
  #64
speedfoos's Avatar
Good idea. That's the best route for your setup aside from going with k-pro which will do everything for you in one shot. Of course it's twice as expensive as the F/IC+VAFC route, but well worth it IMO. I'm ditching my piggyback (PCS-XFC) this fall for it.
Old Jul 27, 2008
  #65
civcspool's Avatar
im also thinking not to change the head anymore and stick with lx head but yea.. ill keep you guys updated when i get everything and do my dyno..
Old Jul 28, 2008
  #66
civcspool's Avatar
What's the difference between vafc and vafc2 can i use vafc ?
Old Jul 28, 2008
  #67
speedfoos's Avatar
Dunno. Never messed with them. Talk to Adam (greeen01civic4d) he just did this one his car and would know better than I would.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mrohitredd
18
May 14, 2015 07:35 PM
HondaHomer
May 14, 2015 12:24 PM
hokiedad4
May 3, 2015 10:06 PM
jessicakaybby
Apr 20, 2015 12:11 PM
