help: replacing head gasket
Old Jun 18, 2008
civcspool's Avatar
civcspool will become famous soon enoughcivcspool will become famous soon enough
i am loosing coolant lately and planning to replace my head gasket my setup is tsi kit running at 7 psi
what parts should i get ? do i need block guard ?
what type of gasket ? and type of head stud?
this is my daily driver people please help me ...
Old Jun 18, 2008
Rufus's Avatar
Re: help: replacing head gasket
ARP headstuds. I'm in the middle of doing mine. 6lbs
Old Jun 18, 2008
civcspool's Avatar
what about the head gasket which one should i get ? there's one being sold at dezod "Cometic Mult-Layer Steel Head Gasket-1.7L D17A1, D17A2, D17A6 (76mm Bore) " but i dont know the mm . i know m engine is stock and i think its 75mm but they are selling 76mm and do i still nees the block guard ?
Old Jun 18, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
i would suggest just going with an OEM honda head gasket and ARP head studs. if you are gonna up the boost in the future it wont hurt to put a block guard but i think it would be unnecessary unless your going to build the block.
Old Jun 18, 2008
andyman97's Avatar
Turbo Guru
OEM headgaskets are fine. Get ARP headstuds for a d16. You don't need a blockguard. If I can run 430 whp on a d17 with no sleeves or gay *** ****ing blockguard, so can you.
What you really need to focus on is what caused the blown headgasket in the first place...
Old Jun 18, 2008
yeah did you overheat or something? too much compression? broken fans? here what you need at the minimum...
-new head bolts (oem is fine or go with arp)
-new head gasket, header gasket, and IM gasket oem fine
-oil and coolant and oil filter
-optional is crank pulley, water pump, and timing belt (and cam gear if yours is bad or you want to put aem on.
check the old head out before putting it back! take it in to a machine shop and have them check for warpage and compression. also a good time to swap in a new cam.
Old Jun 18, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
there is almost never a reason to replace the header gasket or intake mani gasket most dealerships won't even carry them cause there is never a need for them. unless you really screw up, those gasket's are pretty hard to destroy. and there is no reason to replace the crank pulley unless you break it.
you probably blew the had gasket due to bad engine managment or too much boost for stock head studs
Old Jun 18, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
nah .. i don't htink too much boost 7 psi on tsi kit is nothing .. i think jus a bad tune..
Old Jun 18, 2008
you cant reuse crush gaskets man. unless he plans to remove the head with the im and header still attached, which i doubt.
Old Jun 18, 2008
andyman97's Avatar
Turbo Guru
I've reused my stock im and ex mani gaskets more times than I can count and don't have any leaks at all.
Old Jun 18, 2008
i guess it depends on the car then. i reused my header gasket once and had an exhaust leak the next day.
Old Jun 18, 2008
bomerman19's Avatar
yeah I have removed mine like 20-30 times on two different engines and never had any leaks
Old Jun 18, 2008
civcspool's Avatar
not really overheat but I saw the needle at H twice soo I pulled over to the side. lately i keep seeing my coolant reservoir overflowing and i keep putting coolant in my rad. so I am assuming that this is my head gasket gone right? need some input
Old Jun 18, 2008
if the dummy temp gauge was on H, you overheated already and possibly blew the headgasket or warped the head itself.
Old Jun 18, 2008
Rufus's Avatar
Agreed. The head needs to come off vato. Mine is off right now
Old Jun 19, 2008
civcspool's Avatar
so should i go with cometic headgasket or nippon leakless? what size is the nippon oem any ideas?
Old Jun 19, 2008
nippon
Old Jun 19, 2008
civcspool's Avatar
anyone know the part no for arp head studs for d17? im confused on what people are posting
Old Jun 19, 2008
Rufus's Avatar
you need d16yz
http://www.jegs.com/i/ARP/070/208-4301/10002/-1
Old Jun 19, 2008
andyman97's Avatar
Turbo Guru
Originally Posted by Rufus
No "y" in there buddy, just the d16z
Old Jun 19, 2008
Rufus's Avatar
You forgot a period at the end of your sentence.
Old Jun 19, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
Well played. Imaginary +1 for you since rep is gay and we don't have vbPlaza.
Old Jun 20, 2008
andyman97's Avatar
Turbo Guru
You forgot to wipe your chin after I nutted on your face.
Old Jun 20, 2008
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Some things never change
Old Jun 20, 2008
drunkenmagnum's Avatar
Agreed.
you take **** to personal and you have ****ed up more than once youself. Sorry if eveyone doesn't know as much about a ****ing d16 or d17 as you. You are here to help and not point out everytime someone does something different than you or messes things up.
Not everyone wants to spend that much money on a damn budget car, sometimes we just want to make decent power with the parts we have and need direction and help.
You offer great advice and I have come to you many times but sometimes you act like your 12 instead of 28.
Old Jun 20, 2008
andyman97's Avatar
Turbo Guru
WTF are you talking about?
Dallis and I are friends. We talk all the time. This is purely joking between friends....
Old Jun 20, 2008
you tend to be a bit condescending at times is all. Dont take it personal but half the members here know what i am talking about.
Sorry if I seem butt hurt over this and maybe I read your post with the wrong tone. If so, my bad.
Old Jun 20, 2008
andyman97's Avatar
Turbo Guru
I don't care what anyone thinks, to be honest. People who know me know how I am and know that I'm ****ing around most of the time. I will be an ******* to people who open their mouths and let **** fly out, because, imo, they don't need to be putting out that type of misinformation.
But that type of thing, I do take personally. You have to understand that when I first started modding this car, there was no information and almost no part availability for this engine. I had nothing but problems with a piggyback and had to wait around for real management to even come out.
I've gotten bad advice as well as no advice and I can't stand when someone posts bullshit.
Old Jun 20, 2008
Rufus's Avatar
lol I posted a link anyway. I just had to pick Andy apart for little **** because he was doing it to me....bastard guy!
Old Jun 20, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
internetz.
serious bidness.
