vafc2 ?
Old Jan 3, 2008
SScott912's Avatar
SScott912 has a little shameless behaviour in the past
vafc2 ?
i have a 04 honda civic ex 1.7l vtec i recently purchased a vafc2 for my car and i am just wondering if there is any way i can tune it for the rsx injectors any help is appreciated
Old Jan 3, 2008
ronaldo9's Avatar
Re: vafc2 ?
If you are N/A ditch those RSX injectors. You'll be way to rich and the stock injectors are more then adequate to handle your N/A power needs.
Old Jan 3, 2008
speedfoos's Avatar
Re: vafc2 ?
But doesn't the VAFC have the option of tuning with a fuel map?
Old Jan 3, 2008
ronaldo9's Avatar
Re: vafc2 ?
Correct, Clint, but with RSX injectors he'll be pulling fuel EVERYWHERE especially getting that baby to idle. If you don't have access to a dyno shop don't waste your time trying to street tune it.
Old Jan 3, 2008
speedfoos's Avatar
Re: vafc2 ?
Very true. I guess it's just not that difficult when you have a wideband and datalogging software to get things dialed in properly on a street tune. But then we're down the whole cost vs. HP discussion that every NA build thread gets clogged up with. Good point.
Old Jan 3, 2008
ronaldo9's Avatar
Re: vafc2 ?
SSCott912, I'm not trying to discourage you either. If you are not running nitrous and are N/A the rsx injectors will be overkill IMO. I'm not denying you can make a couple hp with a VAFC2; however you would have to go to a dyno shop to tune it. Messing with your air/fuel with no wideband can be detrimental to your engine and you may even lose power.
Case in point I street tuned my car with a wideband when I had my stage 2 cam to what felt good to me and was safe. The map I made yielded 117whp. After getting dyno tuned by a professional I made 124whp with a smoother powerband on the emangle.
Old Jan 3, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: vafc2 ?
When I bought my VAFC2 the first thing i wanted to do was tune with the RSX injectors also...
as ron said its not worth the 1 maybe 2 HP I was also looking at a return fuel systems
Old Jan 3, 2008
SScott912's Avatar
Re: vafc2 ?
thanks guys for your help i will use my stock honda injectors would u suggest getting a walbro 255 fuel pump? would it help out my stock injectors i am planning on running a turbonetics turbo with intercooler on a stock engine
Old Jan 3, 2008
02BLKCIVIC's Avatar
Re: vafc2 ?
go dezod yo
Old Jan 3, 2008
ronaldo9's Avatar
Re: vafc2 ?
WOAH WOAH, you didn't say anything about turbo. IF YOU ARE GOING TURBO; KEEP THE RSX INJECTORS. Sorry for the caps, I did not want to confuse you. I thought you were N/A. Yes, get the walbro 255lph fuel pump. It's not a necessity but will help for sure with a turbo setup. Sorry for the confusion.
Old Jan 3, 2008
SScott912's Avatar
Re: vafc2 ?
alright sounds good so i will be able to adjust my fuel to these rsx injectors and a walbro fuel pump with my vafc2 there is no place to dyno around here in ohio close atleast so any suggestions of a tuning ill def want to dump more fuel correct what about the air more air or less thanks
Old Jan 3, 2008
ronaldo9's Avatar
Re: vafc2 ?
There are plenty of reputable dyno shops in Ohio fyi. They wont' be cheap but they are there. Yes, you will need to add lots of fuel but make sure you buy a wideband 02 sensor at least if you are street tuning. Your turbo will be adding air hence why its called forced induction. The vafc2 controls your fuel not your air and vtec. Same with SAFC2 just w/o vtec. I think you should read the turbo FAQ on the site before you dive into this. You will save yourself alot of headaches and pain in the future.
Old Jan 3, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
Re: vafc2 ?
uhh what? what's your exact location, i guarantee i could give you a reputable tuner.
Old Jan 4, 2008
SScott912's Avatar
Re: vafc2 ?
i live in a town called bluffton near lima and findlay ohio
Old Jan 4, 2008
SScott912's Avatar
Re: vafc2 ?
1 ? what is the difference between a wideband o2 sensor and a narrow band? stock 04 civics are wide or narrow the reason i ask is i got an air/fuel gauge that is narrow band and i have been looking at my wireing skamatics to find which wire is the signal wire for that gauge i have backprobed all 4 lol and this wideband tuner tells me my air mixture is that correct if im running to rich or too lean and any kits u suggest? thanks
Old Jan 4, 2008
speedfoos's Avatar
Re: vafc2 ?
Dude. Wideband reads a signal from 0-5V and narrowband reads from 0-1.2V (or 1.5 can't remember). Either way, you will not get accurate readings from a narrowband and you sure as hell can't tune reliably off one. The signal is, well, wider and is simply more accurately interpreted by a controller than a narrowband is. Don't bother hooking the narrowband A/F gauge up as they've been proven to play hell with your car's electrical system.
For a wideband, I'm running the PLX M200 that they have replaced with the D200. That's a good one. The AEM UEGO is another good one. Look at spending $300 on a good wideband "kit" (sensor, controller, display), but it's well worth it. It will tell you exactly what your AFRs are.
Old Jan 4, 2008
Re: vafc2 ?
oh man, there's definitely tuners in toledo and you're not far from cleveland and akron (where i live) at all!
Rennen
Nov 21, 2006 12:16 AM
aznstylez254
Jun 23, 2006 12:56 AM
jayrck81
Mar 5, 2006 12:31 PM
MiamiUgen7
Sep 12, 2005 05:10 PM
xproductionz
Aug 30, 2004 01:30 PM
