VTEC engagment and limp? - The VERDICT
Old Dec 24, 2007
  #31
DriftR's Avatar
DriftR is an unknown quantity at this point
Re: So who's got the dope on VTEC engagment and limp?
Originally Posted by briand17a2
I had the EXACT same problem after wiring up the VTEC I/O and VTC input wires. All airflow adjust/shiftpoint rotaries were zeroed out, all maps were set to stock in the software. The support tool program recognized the eManage when I went power on. Car started up great, all my indications on the laptop looked great, pulled up the graphs for all parameters and went for a drive.
After a few nervous minutes of hoping my motor wouldnt explode, I decided everything was running safely and started to roll on the throttle. Thats when I noticed a significantly less amount of power from 4k-6k. On the interstate, the damn car would barely make it into 4th gear, almost like it was choking or something...
I thought VTEC was working, because the eManage AUX output signal was indicating HIGH every time I hit the VTEC enable rpm threshold. Either something was seriously wrong with everything else, or VTEC was not engaging, even though the solenoid was getting power.
Thats exactly what I'm going through...and my name's also Brian haha. I didn't know what was causing it even though the graph on the emanage shows the high output. I might have to try civic-driver's recommendation by testing the voltage direct.
But as emjay says, he HAS vtec W/O the primary o2. So that prooves that losing the 02 does not either put you in limp mode OR the limp mode does not mean you lose vtec.
I'm going to reconnect all my vtec circuits back to the ecu and go from there and see if I get to open up my 4000k-redline band.
Old Dec 26, 2007
  #32
briand17a2's Avatar
briand17a2 has a spectacular aura aboutbriand17a2 has a spectacular aura about
Any luck getting to use all the valves? If the eManage brain starts flashing code 14 at you (error in VTEC signal input or output, one long, 4 short red lights), ive been dealing with this for a few months now. I tried shifting the VTEC enable jumpers around, but this did nothing, do ive got the jumpers set up the way Dezod recommended. Let me know how it turns out.
Old Dec 26, 2007
  #33
DriftR's Avatar
Not yet, I haven't had time yet..... since i just got my *** beat by 2 bouncers at a club for absolutly no reason. Had to get some stitches. But I think I'm gonna do it tomorrow morning. It should only be a 20 min job. I'll keep you posted.
Old Jan 2, 2008
  #34
DriftR's Avatar
Ok, guys, I put the vtec wires back into the ECU, ignoring the emanage altogther. And there is vtec. The power is there mid-end rpm range.
That proves, either there is NO limp mode w/o the primary sensor or, there IS vtec in limp mode. Thanks for all the input everyone.
Old Jan 3, 2008
  #35
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
Re: VTEC engagment and limp? - The VERDICT
i told u
Old Jan 10, 2008
  #36
emjay's Avatar
i have a question for all of u to answer ... did any of u with piggyback units see that by unplugging ur o2 sensor it made the afrs more steady?? i noticed that say there is less moving and its afrs are more steady without my O2 sensor .. but when it is plugged, the afrs are always trying to correct each other so i get some fluctuation
Old Jan 10, 2008
  #37
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
lol at gearbox...
Originally Posted by gearbox
it was never meant to be like a turbo boost lol.
Turbo Boost!
[YOUTUBE]http://youtube.com/watch?v=qcDztfFXPww[/YOUTUBE]
Old Jan 23, 2008
  #38
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ LMFAO!!!!!!!!!! :lmao: that was my laugh of the day on the forum today.
Old Jan 23, 2008
  #39
briand17a2's Avatar
haha, oh man good stuff. I have to admit though, I thought knight rider was the **** back in the day. I'd get one of them big wardrobe moving boxes and cut windows in it, then draw a bunch of dials n crap all over the place. Lol, playing in cardboard boxes ftw. All I ever wanted was a car with a bunch of gauges and buttons Gauges and buttons = wtq fer sheezie
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Dave Brabant
Sep 27, 2015 09:43 PM
Luluharp
Sep 27, 2015 11:56 AM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
beanhead
Sep 24, 2015 12:04 PM
