Clocking hot side of t3
Old Oct 15, 2007
2slowem2's Avatar
2slowem2 should not be trusted2slowem2 should not be trusted
i need to clock the hot side of my t3 turbo its a airsearch,i loosened the bolts that hold it in place and tried turning it but its stuck its a used turbo!How do i properly turn this thing i am afraid of damaging the turbo and u all know how expensive they are so please help out its cold and windy outside and i wanna install this turbo but have to clock it first!One more question do u have to run a restrictor on ur oil feed line on a journal bearing turbo?
Old Oct 15, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Clocking hot side of t3
you will want to use a restrictor.... sometimes clocking a turbo thats been used is tough.... a rubber mallet and some tapping should get it to move.
Old Oct 15, 2007
2slowem2's Avatar
I have tried a rubber mallet for like 15 min tryin to get it to loosen up,i cant get it to budge!This thing has the little oil inlet on the bottom and the big outlet facing up when its bolted on my dezod manifold!So i have to clock it to run it this sucks!How hard can hit the turbo to loosen it up and were exactly should i be hittin?
Old Oct 15, 2007
2slowem2's Avatar
i need help!
Old Oct 20, 2007
2slowem2's Avatar
Well i got it clocked after some dead blow hammer hits,the rubber mallet wasnt cuttin igood news is im boosted again and this t3 kicks way more *** than my old lil t25!T3 is the way to go!
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
Sarahwv2910
22
Jun 17, 2015 12:35 PM
4 banger
Jun 5, 2015 01:44 AM
usajags84
May 10, 2015 08:11 AM
