Is there anyone who can answer this question..Anyone at all
Ok im going turbo in about a week or 2..I have all the parts but just not sure where the pressure sensor harness hooks up to..I know it hooks up to the emange but i dont know where the other end hooks up to..If anyone could help me out just let me know..Thanks
Re: Is there anyone who can answer this question..Anyone at all
No idea on emanage sorry. The PCS has a dedicated plug for it. Do you not have the wiring instructions for the emanage? Can you download them from the Greddy site?
I know it connects to the emange but where at on the car..I have the instructions but there in japense
Connects to the brake booster Vacuum line... you gotta splice it. Same goes with your boost controller assuming you have one. Look for a 3/4 diam. black hose near your driverside firewall(back of your engine bay). Get a 3/8 T-fitting, cut the vac line, hook them back up through the T fitting, and hook the last on up to a your pressure sensor via vacuum manifold or reducer connector. You can make your own vac manifold to save money like i did. I'm a cheap a$$. Also that way you can mount it anywhere and have as many output ports as you like feeding your controllers, gauges and gizmos.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Islesfan
Sep 29, 2015 03:42 AM
NROD315
Sep 23, 2015 03:46 PM
