K24 Swap Question...
Old Aug 15, 2007
civ_nate's Avatar
civ_nate is an unknown quantity at this point
i was wondering, ,i found sum1 selling a k24a1 /w a tsx head and type s cams... its a long block so, will a type s 6-speed tranny bolt up? i assume so.... also, ,will i need the k ecu or do i ahve to use aftermarket engine management? im just starting to look into the swap thing as an option, i tried doing some research but most of the topics i found about this were a question and then 5 pages of falmming him for asking.... im at work so i cant really spend hours searching and i need to know soon... tks guys appreciate the help...
Old Aug 15, 2007
cujo1400's Avatar
cujo1400 is an unknown quantity at this point
Re: K24 Swap Question...
6 speed will bolt up and you will need kpro
Old Aug 15, 2007
TemjinX2's Avatar
there's a diy on this, but short answer is. Any k series tranny will bolt up. You can use the stock k series ecu or a kpro. if you use stock ecu you need to reprogram your key to match the ecu or you cant bypass immobilizer.
Kpro = get more power out and bypasses immobilzer.
Old Aug 15, 2007
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
yep what they said..... KPRO is your friend. its mine too.
Old Aug 16, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
You are better off using KPRO because a stock ECU would not run this motor properly because the head has been changed.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
