HELP!! civic Ex turbo ...Emange question
Old May 29, 2007
kaesonthompson's Avatar
kaesonthompson is an unknown quantity at this point
Can anyone say if i need to use the Greddy pressure sensor? I'm running 8psi of boost. Anyone had any issues with the stock map sensor? Help!
Old May 30, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
Re: HELP!! civic Ex turbo ...Emange question
you SHOULD get the greddy pressure sensor. without it it will be really hard to tune the emanage with boost. the the pressure sensor you can tune off of a boost reference rather than throttle reference if im not mistaken. if you run without the greddy pressure sensor you will probably be only to get a good full throttle tune and not partial throttle tune. the stock MAP sensor is fine, just use the emanage voltage clamp feature to keep the sensor from seeing boost, or you can get a missing link (synapse). hope this helped you, rep me if it did!
for more information read the emanage faq.
Old May 30, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
What he said.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
dano2005
Apr 14, 2015 01:58 AM
colombianDXcivic
Bolt-on Engine Performance
Nov 8, 2001 12:14 AM
supraman
Nov 6, 2001 05:50 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
