Turbo set help please
Old Apr 17, 2007
BigD001's Avatar
BigD001 can only hope to improve
Ok I want to turbo my car and i have a few questions.
Im goin with dezod manifold and i want to know which Garrett T3/TO4E to go with, far as trim goes does it matter like with the lag?I only want to boost at max 6 or 7psi for a daliy driver so i can get an 240sx and build that up to drag with, And the last question i have is I'll be going with greddy E and i wanted to know if thiers any good tuners around arkansas or texas that can tune my car.
Old Apr 17, 2007
ronaldo9's Avatar
Re: Turbo set help please
As far as turbo I believe dezod uses 50trim or less for quick spool. Plenty of sick tuners out in Texas so just keep searching and asking. Good luck with your build.
Old Apr 17, 2007
affixrider's Avatar
affixrider will become famous soon enough
hey man im from arkansas, yeah there are a few places in little rock, and one in conway. ill try to find their names and exact location if youd like. let me know.
Old Apr 18, 2007
BigD001's Avatar
Yeah I would like the names thanks for the help, Hey since your from arkansas do you know anyone that adjust and alline our cars with a camber kit. Im new to i state and i know thing about the shops out here
Old Apr 18, 2007
andyman97's Avatar
Turbo Guru
t25 would be your best choice for spoolup time, it'll spool faster than a t3/t4 but dezod's manifold isn't foot printed for a t25...
Old Apr 18, 2007
C2i0v0i1C's Avatar
SuperMODrizd
jotech in texas
Old Apr 18, 2007
andyman97's Avatar
Turbo Guru
Originally Posted by C2i0v0i1C
jotech in texas
Go to T1, Tony knows what he's doing. He tuned my car.
Old Apr 18, 2007
BigD001's Avatar
Yeah i know a t25 has a faster spool time then a t3 but i would rather have it just in case i want to boost alot more one day. So T1 is who tuned your car andy?where are they in texas
Old Apr 18, 2007
andyman97's Avatar
Turbo Guru
Rowlett, suburb of NE Dallas. You were asking about the best turbo for 7-8 psi, no mention of a hp goal....
Old Apr 18, 2007
Michalo187's Avatar
Abortion Survivor
I think it all depends on what hp you want. Some turbos will spool faster than others but the power just wont be there. T3 super 60 is a super fast spooling turbo that probably won't give you the power you want. T3/to4e with a 50 trim will spool pretty quick and give you quite a bit more power advantage and high end over the super 60.
Old Apr 19, 2007
BigD001's Avatar
Pretty much i want a t3-t4 that doesn't lag like some turbo cars i've been in like the sti, srt4 stage 2 and elcipse boosten 18psi and be able to push some hp down if i ever want to build my car up to handle like max high 200's. I should of said this to start out with, sorry guy for not post the right questions at the right time thanks for the help
Old Apr 19, 2007
tfnaaf's Avatar
BLDNPSI Mod
best of both worlds.... GT28R or GT28RS.....
Old Apr 20, 2007
dezod's Avatar
7thgen Power Maker
Manifold design plays heavy into lag. We where able to cut lag down significantly with our manifold designs.
Old Apr 28, 2007
2slowem2's Avatar
2slowem2 should not be trusted2slowem2 should not be trusted
What about a garrett gt25r i got it cheap and its ball bearing i reccomend!
Jaryn
May 17, 2016 02:52 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
