Acura RDX swap
Old Apr 17, 2007
2k2civicsedan's Avatar
2k2civicsedan is an unknown quantity at this point
Acura RDX swap
I have a question. I know the RDX is still very new so the engine is still pricey. But has anyone heard about the ability to swap the engine in a 7th gen? I think that it would be better then the K20 and the K24 because its already turboed. I think it has 240 hp and 260 ft.lbs. Thats 40 more hp and 100 more ft.lbs then the k24 and you can just upgrade the turbo instead of buying a complete kit. I don't have the money to do this I was just seeing I anyone has heard anything about it yet? Thanks.
Old Apr 17, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
Re: Acura RDX swap
im pretty sure its electronic throttle...making the swap in any car almost impossible
Old Apr 17, 2007
AmbulanceMonkee's Avatar
Re: Acura RDX swap
It could probably be made to work eventually, but it would end up being cheaper, and easier to swap, then turbo/supercharge a K20/24.
Old Apr 17, 2007
kasimmmmm's Avatar
Re: Acura RDX swap
give it time... i bet you someone's going to do it.
Old Apr 17, 2007
Pwning Noobs 24/7
Re: Acura RDX swap
i also remember hearing that the motor is taller than D-series so if it was possible...there would be hood clearance issues
Old Apr 17, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Acura RDX swap
The way the block is cast... it'll only work with the SH-AWD transmission.... so um, Unless you want to do an AWD conversion and spend lots of money, frankenstein is the way to go.
Not to mention its mass air metered, the turbo is integrated into the manifold, the throttle faces up and backwards, adding an intercooler on top probably also makes the motor too tall to clear any car hood.
Old Apr 17, 2007
drunkenmagnum's Avatar
Re: Acura RDX swap
https://www.civicforums.com/forums/7...-k23turbo.html
https://www.civicforums.com/forums/7...3a1-turbo.html
search button- try it
Old Apr 17, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Re: Acura RDX swap
Its already been tried and failed, look on ephatch.com or k20a.org.
Old Apr 17, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: Acura RDX swap
yep!
I heard something about the engine mounts too..
The subject has been openly talked about though.
Old Apr 17, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Re: Acura RDX swap
I don't think it's worth the hassle. Is it possible, sure it is! anything is possible. But to make this thing as popular as the K20 or the B series swap is next to nothing at all. Honda really needs to come out with a sport compact turbo. I heard the 07 s2000 is going to be turbo.
Old Apr 17, 2007
ragingSPAM's Avatar
I just burnt my tongue
Re: Acura RDX swap
well from the original post in this thread you can get as good of #'s with a franken swap as boilmaker was saying...if u look at it hondaluver before he did any building i got 232 whp, and 209lbs i believe...and some people on k20a.org i've seen #'s of 270whp
Old Apr 17, 2007
Re: Acura RDX swap
Someone lock this please...
http://www.ephatch.com/forum/showthr...&highlight=k23
any more dumb questions?
Scout1
Oct 5, 2015 01:33 PM
Dave Brabant
Sep 27, 2015 09:43 PM
PunX
Sep 23, 2015 10:45 PM
Jrosa
Sep 14, 2015 08:24 PM
Hatchness
Sep 14, 2015 09:02 AM
