Good read: Acura K23A1 Turbo
Old Aug 25, 2006
dezod's Avatar
7thgen Power Maker
ACURA’S FIRST TURBO: WILL IT BOOST TUNER’S INTEREST?
Honda’s new hefty K-Series engine provides a performance boost for SUV consumers and could possibly offer insight into Honda’s engineering forecast. Developed specifically for the RDX, Acura’s compact sport-utility, the engine has been modified to accept the strain of a turbocharger; a brand first.
The major feature of the new system is a variable flow turbo (VFT), designed to regulate airflow with an actuator built within the turbo housing. Exhaust air is progressively directed into two main chambers, diverting air into the smaller chamber when air pressure is low, and throughout the entire system when air pressure is high. Controlled by the engine’s ECU, the computer determines the necessary level of flow to achieve efficient boost and desired power. Under these conditions, the impeller is able to spin quickly at low RPMs, eliminating relatively all turbo-lag and providing seamless force throughout the power band.
Similar attempts have been made by other manufacturers, but moving parts were often exposed to hot exhaust air, increasing repair costs and the frequency of failures. Honda’s straightforward technology places the inlet device in front of the turbine, insulated from the excessive heat, and thus substantially increasing durability.
The engine, named the K23A1, generates more torque than any other product Honda has sent to the United States, but thanks to the revolutionary i-VTEC technology the engine is respectably frugal. The potential for enthusiasts lies in the architecture, as it is closely related to the K-Series engines found in the RSX, TSX, and Civic Si. Engineers realized the additional burden they would be placing on the engine with the turbo, so the block was heavily reinforced, iron liners were added to cope with pressure and the crankshaft and connecting rods have been forged.
Due to this meaty reinforcement a direct engine swap is not possible. Nevertheless, this provides specialty equipment manufacturers with an opportunity to construct mounts and miscellaneous parts which will accommodate this engine. Given the popularity of engine swaps and the muscular structure of the K23A1, it is conceivable that enthusiasts will adopt this as their next project.
In the April, 2006 edition of Super Street magazine, they ranked the “Top Ten Engines” of the last decade in regard to the compact performance industry. Honda produced three from the list: B16/B18, D16, K20. The K-Series is the most current of the bunch and should continue to be a tuner favorite, especially now that it’s available in a turbocharged version.
Old Aug 25, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
i wouldn't mind poping my hood and seeing that under it....lol...maybe honda will have a coupe/sedan of some sort with it
Old Aug 25, 2006
jester444's Avatar
Dain Bramaged.
jester444 is an unknown quantity at this point
I think I heard somewhere that engine or something like it may work its way into other cars in the Honda/Acura line.
Old Aug 25, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
if the swap was possible...what about the whole trans thing? use an rsx trans?
Old Aug 25, 2006
burke420's Avatar
The World Is Yours!
idk about that, but a type s or type r are expensive enough, let alone this breed of motor.....
Old Aug 25, 2006
diskreet's Avatar
Smart change over VGT turbos
Old Aug 25, 2006
doesnt the turbo = less strain on motor to get up to speed?
isnt that why toyota is slowly converting to turbo hybrid?
Old Aug 25, 2006
i think i read somewhere that you can't use the rsx trans or somthing...that's why this is not a great option for a swap....could be wrong though
Old Aug 25, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
What are the torque specs on this? This thing puts out more torque then the Ridgeline?
Old Aug 26, 2006
dezod's Avatar
7thgen Power Maker
This is from a SEMA article I received. This is the entire article. I don't know.
Old Aug 26, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
just seems to me that swap will never work because of the shear size of eveything under the hood, even if you did rework the intercooler.
Old Aug 26, 2006
02nithwkcivcpe's Avatar
02nithwkcivcpe is an unknown quantity at this point
i think it has like 240 or 260 ft/lbs
Old Aug 26, 2006
Michalo187's Avatar
Abortion Survivor
thats a badass motor and badass technology but doubt anyone swaps them
Old Aug 26, 2006
diskreet's Avatar
Give it time. If people fit an LS1 into an RX7 then I'm sure this can fit into something in the Honda line.
Old Aug 26, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
im trying to convince my parents into getting one of these. if i can then ill put my civic back to stock and they can drive it :P oh man, im already getting gittery thinking about this . of course ill wait till the 2nd or 3rd yr :P
Old Aug 28, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
same turbo concept that porsche has out for the past couple years with their 911 or 997 i believe. opens a valve at a higher rpm to let more exhaust gas in and thus have good low and high band power
Old Aug 28, 2006
gelshmoff's Avatar
gelshmoff is an unknown quantity at this point
that is my prediction as well. I think they will use this engine (or a variant) on an rsx-replacement. I can't believe acura would go without an integra/rsx type car for very long. just my 02.
Old Aug 28, 2006
eye_see_you's Avatar
let the devil out
I would love to swap that out with my current k20a2.. it would be interesting
Old Aug 28, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
I saw a k23a1 in a RDX yesterday and I just dont see how it could fit. But I would say the same thing about the K24 in the passport.
Old Nov 28, 2006
Blk2k2civy's Avatar
Blk2k2civy is an unknown quantity at this point
I don't think it would clear the hood at all unless you have a custom FMIC setup but i was looking at where the transmission mounts and looks weird would a rsxs tran fit on it at all with a custome adapter of some kind. maybe skunk2 or somebody can fabricate that IM with the throttle body facing down. that cam looks diffirent from the 3 lobe cam from the rsxs. anyways their is still the problem of having custom motor mounts
http://www.rdxdrivers.com/forums/index.php?topic=29.0
ID:	68700   Click image for larger version
ID:	68701   Click image for larger version
Old Nov 28, 2006
HondaLuver's Avatar
Its a celebration bitches!
this would fit because a few items
the mounts are diffrent from a standard k20/k24
custom intercooler needed
it uses a 4wd automatic transmition. you need a k20 transmition to fit in a swap
the head is the same as a k20a3(si motor), it does not have full 3 lobe I-vtec cams
its basically a 86mmx99mm 2.3 liter. which is a debored k24 (87mmx99mm)
you can't put the pistons in a k24. maybe the rods. but its probably cheaper getting aftermarket.
it would probably be cheaper to do a k24a1/k20a2 head and slap a turbo on with better numbers
Old Nov 28, 2006
tougEMII's Avatar
tougEMII has a spectacular aura abouttougEMII has a spectacular aura about
yeah cudnt u just get that turbo off the rdx and jus swap it on a 24/20??...nvm if the rdx has a good strong block
Old Nov 28, 2006
familycar's Avatar
i have read a few articles on the new RDX and it has been said by my wife and i that after the vic is paid off that is her next car. i take over the vic and take the dc off the road
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
