intake manifold choice for turbo setup
Old Apr 12, 2007
ST8RACE's Avatar
ST8RACE has a spectacular aura aboutST8RACE has a spectacular aura aboutST8RACE has a spectacular aura about
im undecided on a y8 manifold conversion for d17 turbo or a jdm fabtech manifold ones 150.00 the other 1,200.00. i know you pay for quality. but does any one know what the y8 will take for boost .anyone have feedback on this decision. how about andyman,looking for feedback .thanks
Old Apr 12, 2007
andyman97's Avatar
Turbo Guru
Re: intake manifold choice for turbo setup
Obviously a custom manifold is going to flow better than a y8 and a y8 will flow alot better than stock. Good luck with jdm fabtech, gery is a busy man.
Something I would try if I were limited on options is a y8 performer X edelbrock intake if it would fit.
Old Apr 12, 2007
ST8RACE's Avatar
what about a y8 venom intake, i saw one on the 396 hp civic on the forum awhile ago. i know the skunk2 will not fit to big.
Old Apr 12, 2007
andyman97's Avatar
Turbo Guru
If you know it was for a y8, then it may fit, go for it.
Old Apr 13, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
$150? Buy a Y8 version of a manifold for now. Your going to need some more money when you figure out that the 440s and emanage dont mix, hehe. Save for the K-pro setup mang.
Old Apr 13, 2007
ST8RACE's Avatar
why would the 440 injectors not work with the e-management. you have a some insite please share if you dont mind. thanks
Old Apr 13, 2007
dezod's Avatar
7thgen Power Maker
Old news! CELs caused by the e-manage injector correction factor.
Posted in 2004 by us:
https://www.civicforums.com/forums/7...-link-cel.html
Old Apr 13, 2007
andyman97's Avatar
Turbo Guru
Recheck that thread Paul.
Old Apr 14, 2007
tfnaaf's Avatar
BLDNPSI Mod
Im curious if anyone has tried the e-manage with the additional injecor feature?
Old Apr 14, 2007
dezod's Avatar
7thgen Power Maker
Responded to, and it is a bit more than tuning. It is massaging, tuning and lots of datalogging with trial and error.
Old Apr 14, 2007
dezod's Avatar
7thgen Power Maker
Upstream injectors?
Old Apr 14, 2007
andyman97's Avatar
Turbo Guru
I've seen a setup with stock injectors, emanage, 2 additional 550 injectors with the tsi fuel setup all together. Not a great choice for management but it works.
Old Apr 14, 2007
tfnaaf's Avatar
BLDNPSI Mod
Originally Posted by dezod
Upstream injectors?
Not exzactly, but you know how the edlebrock turbo system uses extra injectors that are mounted on the underside of the intake manifold? If you look in the picture bellow you'll know what i mean.
As i recall e-manage has the capability to control extra injectors along with the stock injectors? So in therory you could control tsi style injectors AND say rsx/rdx/whatever injectors that emanage can handle with its correction factor. And use the extra injectors for boost only fuel enrichment by either a tsi type setup or if you had a earlier aluminum intake that fit and had extra bosses welded in place on each runner? Or the edlebrock y8 turbo kit manifold. Im not 100% sure e-manage is capable of this or not. Either way food for thought!
Old Apr 14, 2007
andyman97's Avatar
Turbo Guru
From what I recall, the emanage can control up to six sequential injectors and up to 2 additional sub injectors. Don't hold me to that but that's what I remember....
Old Apr 15, 2007
tfnaaf's Avatar
BLDNPSI Mod
i think that e-manage with 4 secondary injectors on say a y8 style manifold would be a nice set-up for a high hp set-up
Old Apr 15, 2007
andyman97's Avatar
Turbo Guru
I remember Mike had a setup similar to that with his gsr manifold. I think he was running emanage on it. I can't quite recall how he had the second set of injectors set to fire though....
Old Apr 15, 2007
dezod's Avatar
7thgen Power Maker
That is what I meant by upstream. However, I am not a fan of this method because it is difficult to ensure the fuel gets divided equally amongst the cylinders properly. If it does not, you will get some reach, and some lean....
Old Apr 15, 2007
tfnaaf's Avatar
BLDNPSI Mod
i can see what you mean by upstream with the tsi system, but if the injectors are located 1 per intake runner as in the edelbrock intake system that shouldnt be an issue
Old Apr 17, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
Skunk2 manifold wont fit unless you grind of some of the firewall..i posted a diy on how to swap a y8 manifold onto our cars, if you ST8RACE check out D-series.org there are some heated turbo discussions over there
Old Apr 17, 2007
dezod's Avatar
7thgen Power Maker
That would be 'secondary injectors'
Old Apr 17, 2007
Civicman1988's Avatar
get a custom made intake manifold
Old Apr 18, 2007
Michalo187's Avatar
Abortion Survivor
^^^^^ hell yeah there are so many people that can make custom ones. Also emanage sucks ems is way better, less headaches, less problems and from what i hear k pro is even way better than ems.
herbiej
22
Aug 23, 2015 01:02 PM
cukaracha
Aug 10, 2015 08:01 AM
Theshwartz35
Jul 17, 2015 11:13 PM
hoofboy
Jul 17, 2015 04:27 PM
Ccoop87
Jul 9, 2015 03:26 PM
