A little backdoor action.....
Old Feb 3, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Ah yes, boost can be dirty
Just bolted up the new intercooler, and I must say, I'm spent.
I got sick of all the damn pipes rattling around in the frame pass through, no room, too many pipes and they were so damn long.... so when I had the new one made, I backdoored the hot side of the IC. Took at least 3 feet of piping out of the system, the IC is 7" tall and I can use the whole thing (its not a U)... the trick was I made use of that space behind the bumper.
I stole a page out of Greddy's book and did the up and over pipe. The design of it is actually pretty good if you direct the air right. The air goes in from the top and feeds down, across the air passages. This spreads the air out more evenly and only forces it to make a single turn. The outlet is parallel to the core passages, it keeps it from hitting a wall and having to turn too hard.
Greddy's requires you to remove the crash bar. I was hell bent on not removing it. In total, I had to remove a section about 4" long and about 3/4" deep in the bottom rail of the crash bar to pass the elbow through. Their pipe is centered on the tank... I offset it towards the back of the intercooler so I could keep the crash bar intact. Then I made use of the channel to run the pipe. A 2" pipe will lay right in that channel with room to clear the condenser.
Ignore all the couplers, all this stuff will be welded. I needed to figure out how to run all this, and sort out where to break the pipes so they went in. The only thing thats a pain is that the charge pipe needs to be assembled with the crash bar off, then the IC/pipe and crash bar all bolt to the car together by re-attaching the crash bar to the frame.
And now the fun... the backdoor.
Instead of going down and around, I went through. I drilled a hole in the radiator shroud, which as far as I can tell has 0 structural significance given that it abuts the frame rail which is boxed in. It seems all it does is keep air from passing by the radiator. The pipe never leaves the crash bar rail, it just turns backwards and passes through the shroud.
On the other side, its a matter of turning it and aiming it at the turbo
And yes, It came out looking nasty
I havent decided what I'm gonna do with the paint job.I may leave the core black and the tanks polished, or I may just black it all out.
Old Feb 3, 2007
AmbulanceMonkee's Avatar
looks good. makes me want a turbo, the there's no way that's happening anytime soo.
Old Feb 3, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
put something in front of it and keep ur car a sleeper, lol. Don't show it off. At least i wouldn't.
Old Feb 3, 2007
tfnaaf's Avatar
BLDNPSI Mod
Nice work man! BTW my tranny exploded 2 days ago
Old Feb 4, 2007
hondoer27's Avatar
hondoer27 will become famous soon enoughhondoer27 will become famous soon enough
Flat black that thing
SLEEPER
Old Feb 4, 2007
TRIZ's Avatar
pretty damn nice. I'm suprised you were able to yank out that much piping!
How long did all that end up taking?
Old Feb 4, 2007
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
i'd say paint the end tanks black too to give that sleeper look. but i think it looks badass with just the core black and end tanks polished!
Old Feb 4, 2007
sl33pyriceboi's Avatar
more pixs of ur car boilermarker1 !!!!!!!!!!!
Old Feb 4, 2007
HondaKorn's Avatar
Life is better with 5lug
that looks soo bad ***!!
Old Feb 4, 2007
kasimmmmm's Avatar
clean bro.... love the way you ran your pipes, never seen that done here. good job!
Old Feb 4, 2007
TeLLy's Avatar
Yes, it's an Acura EL
Genius....sheer genius. I swear BM1 is my Civic hero.;...it seems I've been getting a lot of mod inspiration from you lately bud.
Old Feb 4, 2007
Jap-Euro Fusion
Its hard to tell. My tools rebelled on me, so a lot of stuff took longer than it should have. First the dremel went, making the crash bar trim take a while longer than expected. Then my cordless drill crapped out, so I finally gave up on it and drove it across the garage and ran the hole with a corded one. Obviously with the car in pieces, I couldnt go anywhere for new stuff. I wound up using a drill and drilling enough holes in the crash bar to smash it out then clean it up with a grinder. Since I'm not supposed to be working on the car in my apartment's garage (it doesnt actually say that anywhere, but everytime I do it they yell at me) I had the car stashed in the corner and was doing it here and there so as to not attract attention.
It probably took me 5-7 hrs to rig it up, but it always takes me longer to do stuff like this because I need to think about how to do it and line everything up before I start hacking stuff up.
Old Feb 5, 2007
andyman97's Avatar
Turbo Guru
Did you ever consider switching to a slimline and doing a true backdoor? I have yet to see that done on an em2 but have been thinking for awhile that I'd love to do it.
Old Feb 5, 2007
Jap-Euro Fusion
A couple things stop the real backdoor for me.
You'd need to flip the turbo compressor to face left. To have the room, you'd need to pull the PS and probably the AC compressor to do it.
To shorten the radiator core (and condenser) to pull it through the hole, I'd need to make the radiator fatter to keep the coolant supply the same... I havent tested it yet, but I already have overheat worries about taking this thing on the race track, but there's not much room backwards to fatten it (the turbo is already notched into the core support). It probably also means no more room for AC condenser.
I need another manifold, DP and compressor housing (there's an elbow welded on mine) to allow for the flip.
If I went crazy, yeah I'd think about doing a true backdoor, the piping gets so short the response is even more immediate, but to make it happen is a little too over the top for me to go with it right now.
Old Feb 5, 2007
drunkenmagnum's Avatar
get some better engine pics
Old Feb 5, 2007
skipbarber's Avatar
changing your clutch is gonna be fun...
Old Feb 11, 2007
C2i0v0i1C's Avatar
SuperMODrizd
at first i thought u were using ductape at first then i kept scrolling down....shewwww! nice job though
Old Feb 11, 2007
cj2185's Avatar
cj2185 is an unknown quantity at this point
Nice work. YA more engine pics.
Old Feb 12, 2007
Jap-Euro Fusion
Nah, the duct tape was holding that styrofoam thing onto the front of it.... it was easier to just cut it than peel it off.
1SlowSi
Jan 24, 2009 08:48 AM
Pharoh
Jul 18, 2003 12:46 AM
