light weight flywheel worth it on turbo set up?
Old Jan 24, 2007
ST8RACE's Avatar
ST8RACE has a spectacular aura aboutST8RACE has a spectacular aura aboutST8RACE has a spectacular aura about
have a B & M short throw shifter,stage 3 clutch, the big Q: is the light weight flywheel worth doing with a turbo set up. let me know .thanks .
Old Jan 24, 2007
ronaldo9's Avatar
Your rpms will rise faster but the downside is they will fall faster so if you don't shift fast enough you might fall out of your power band. If nething the flywheel might make your car harder to move off the line w/o peeling out with that stage 3 clutch.
Old Jan 24, 2007
familycar's Avatar
flywheels arent really that great for turbo cars because the rpms fall to fast between shifts making you have to work harder to get the turbo spooled again.
Old Jan 27, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
I've always been told that regardless of the fact that your car is turbocharged or not, installing a flywheel would be of great benefit, since it weighs less, it has reduced rotational mass, therefore more existing power is transferred through the drivetrain and subsequently, to the ground. Quicker revs yes, but will it be more difficult to shift between gears, I've never heard that before. Plus, the collected inertia by regular driving will translate into momentum keeping it spinning as you shift....Honestly, I don't have a flywheel installed so I don't know how credibile my opinion is....I just thought clutch and flywheel replacements were good.
Old Jan 27, 2007
bluesteelrock's Avatar
bluesteelrock is an unknown quantity at this point
when I got my clutch and bearings done the person advised me if I changed the flywheel , cause its lighter it might unbalance the entire engine, its just what I heard ???
Old Jan 27, 2007
Eyger's Avatar
Again, I've never heard that before. If that happened when you replaced the flywheel, I think I would have read about it on the manufacturers website or at least somewhere. When I read articles in tuning magazines, whenever someone replaces the clutch, they replace the flywheel too.
Old Jan 27, 2007
ST8RACE's Avatar
THANKS FOR ALL THE REPLYS, IM GOING TO INSTALL THE FLYWHEEL.
I HAVE A STEEL LIGHT WEIGHT FLYWHEEL 11 LB.
ITS GOING IN . I THINK IT WILL BENIFIT ME. THANKS.
Old Jan 27, 2007
hondoer27's Avatar
hondoer27 will become famous soon enoughhondoer27 will become famous soon enough
Keep us updated
Old Jan 27, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
The flywheel itself should be balanced. The engine isn't balanced with the FW on it, so as long as the flywheel itself isnt out of whack it should be fine.
The issue often encountered is the steel friction surface and the aluminum ring gear dont always stay together.
The whole inertia thing.... the more the turbo is spooled, the better off it is obviously, the revs drop very quickly when the clutch is disengaged, but its a matter of you rev-matching the shift to compensate.
I dont necessarily see the benefit to the expense of double a stock FW when the stocker isn't all that heavy to begin with.
Old Jan 28, 2007
nismostreets21's Avatar
nismostreets21 can only hope to improve
t3/t4 8psi stage 3 act xtreme pressure plate and 8lbs flywheel
Putfile - 04 civic turbo 0 80 vid
Old Jan 28, 2007
speedfoos's Avatar
LOL - Seat belts son!
Guess there's proof that the RPM's don't fall too quickly!
Heheh. Turbos are cool.
Old Jan 28, 2007
ST8RACE's Avatar
THANKS FOR THE VID. IT SHOWS THE RPMS NEVER WENT UNDER 4,OOO RPMS . THANKS FOR THE ADDED BACK UP INFO.
Old Jan 29, 2007
familycar's Avatar
your right to a certain extent. remember that inertia is greater with more weight, once the weight is removed its easier for the motor to slow the lighter flywheel down and much faster.
you have to be very good at shifting to keep the rpms high. this actually takes its toll on the tranny because of the harder faster shifts as well. I have the act streetlight flywheel and felt a huge difference in how the car performs. honestly its not the most desirable for a DD.
Old Jan 29, 2007
familycar's Avatar
stock flywheel weighs 19lbs. its pretty heavy actually
Old Jan 29, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I have a 7lbs fidanza flywheel and Exedy Street disk...
if you want, ill answer any questions you may have.
Old Jan 29, 2007
sil04ver's Avatar
sil04ver is an unknown quantity at this point
what about on an N/A em2? when i replace my clutch, i always figured I'd throw in an 11lb flywheel from dezod, would it really be that bad to DD?
Old Jan 29, 2007
familycar's Avatar
no its not that bad. just have to rev a little higher to take off and keep sthe revs up or it will bog. also have to rev match between shifts if you want to keep your rpms up.
Old Jan 29, 2007
speedfoos's Avatar
I just ordered an 11 lb flywheel to go with my new Exedy clutch. My ride is NA (for now) so I'll let you know how it is once it arrives and I install it (should be a couple weeks before it gets here). Search for my Gripforce Clutches thread to see which one I bought for my EM2.
Old Jan 31, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
its funny how just a few threads down from this i have a topic that talks about clutches and flywheels and the disadvantage of light vs heavy.. lol.. anyways.. read this
https://www.civicforums.com/forums/7...explained.html
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
werdnahall
May 17, 2015 11:37 AM
cukaracha
May 16, 2015 02:11 PM
oneheadlight
Apr 29, 2015 11:30 PM
SimDogg
Nov 27, 2001 04:20 PM
