low boost bov?
Old Jan 9, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
low boost bov?
whats a bov good for low boost app? 8psi regular 12psi max. i was looking at the turboxs rfl but it states its good at 10-25 psi or would that not be a problem?
Old Jan 9, 2007
ronaldo9's Avatar
Dezod praises the tial bov and his kit comes setup for 5-6 psi so you might want to consider that too. Plus they sound sick as hell but I guess any bov would sound good being turbo lol.
Old Jan 9, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
lots of BOVs have changable springs. Find one that does, install the low boost spring.
Old Jan 9, 2007
sweet thanks. tial is on the list now. i was lookin at the hks ssqv as well, it says that by the way its designed it can handle any boost level without adjustment.
Old Jan 10, 2007
civic01vtec's Avatar
I really don't consider 8-12psi low boost. You could always cut the spring on the bov, but they could leak then. The hks ssqv is a real nice choice.
Old Jan 10, 2007
2k3civicSSM's Avatar
2k3civicSSM is an unknown quantity at this point
hks ssqv ftw
Old Jan 12, 2007
HyaBoosta's Avatar
Greddy RS or Type S will work fine for that Only real big boost BOV is the Greddy Type R. at 10 psi it wouldn't budge on the softest setting
Old Jan 13, 2007
i have a picture of your engine bay with the turbo in it <3 love it.
Old Jan 13, 2007
dezod's Avatar
7thgen Power Maker
Well TiAL has the option of 3 spring rates, but none have to do with boost settings. The spring is chosen based upon how many inches of mercurcy you pull at a warmed up idle.
Old Jan 13, 2007
dezod's Avatar
7thgen Power Maker
HKS SSQV came down in price, and is a good alternative.
Dezod Motorsports. HKS Super Sequential Blow-Off Valve-Universal fitment (for turbo applications only)
Old Jan 14, 2007
sweet. thanks everyone. i actually bought the turboxs type s bov. good for 1-12psi of boost, perfect jsut what i needed! only got it for 35 shipped too!
Old Jan 15, 2007
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
idk but i love my tial bov i got in the dezod v3 kit, it can be herd a few blocks away. in the car it sounds like it flutters but when drivein by and from a few blocks away its a loud pshhhh.
Old Jan 16, 2007
doesnt a flutter noise mean compressor surge?
Old Jan 16, 2007
Jap-Euro Fusion
a lot of them will flutter open when there's not enough boost to force the plunger all the way open. Its not surge, its just not enough air pressure to force the plunger all the way up. You'll know when its surge.
Old Jan 17, 2007
because with my dsm bov that i am running right now, i hear the PSSSHHH then the flutter noise following the PSH. and when running partial throttle, approaching boost or in low boost all i get is a flutter and no PSH. i think i am getting compressor surge. the bov was crushed by the previous owner of it. i think he crushed it way too much because the nipple of the bov is actually pressed against the diaphram of the bov and angled upward about 5 degrees. i removed the bov and tried pressing the plunger/piston of the bov up all the way with a very decent amount of strength and it only went up lets say, 5 millimeters. i have the turboxs type s bov coming in soon though i just need to buy the adaptor for my flange to bolt it on. after finding this out i checked if there was any shaft play on the wheel of my turbo and its as stiff as it was when i got it , no shaft play. hopefully everything works out alright. thanks for your help everyone!
Old Jan 18, 2007
Jap-Euro Fusion
Change the valve. it may not be closing if the valve was messed up by crushing it. For cheap-sake, just put a stock 1G valve on it and see if it solves it.
Old Feb 23, 2007
nismostreets21's Avatar
nismostreets21 can only hope to improve
i used an eclipse 1g bov good upto 18psi and makes a nice fluttering sound
Old Feb 25, 2007
i was currently using the dsm 1gbov but mine was improperly crushed. i am now using the turboxs type s bov. works great and sounds sick. i would recomend it to anyone
CraigW
Aug 18, 2015 07:06 AM
JDMnoob
Aug 2, 2015 02:38 PM
alxz310
Jul 30, 2015 12:18 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
