Need to disable something in e-manage
Old Jan 4, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Emanage has control of VTEC right now and its holding the engagement point too high. I need to get the crossover back in the hands of the ECU so the valve opens when it should.
I'm thinking just cut the wire in the PNP harness, but I dont know which one to cut. If I cut the wire though, would that just prevent e-manage from modifying the signal? or is that going to break the circuit for the solenoid and keep it from opening all together?
Need the easiest way to deal with this... "shutting it off" in the support tool doesnt help, it just keeps the solenoid shut.
So what color wire in the harness needs to be cut, and would that actually do the job? If I need to connect that wire end to another one, what am I connecting (I assume there's 1 wire in and 1 wire out of the e-manage that would need to be linked if this is the case).
Old Jan 5, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I'm not emange expert, but I'd try to experiment with following and see if its going to work.
I'd rewire emange and bypass vtec all together. I'd rewire only vtec solenoid wire directly to Honda Ecu, just like it was done at the factory.
I'd think this will allow vtec to bypass emanage and be controlled by Honda ECU instead.
Old Jan 5, 2007
ronaldo9's Avatar
I thought the PNP harness doesn't even have VTEC wired in. I'll send you a PM tonight when I get home from work to show you my settings on my emanage. Also what version of emanage are you using? I'm using 1.49. If you have aim that would be better bc then I can just send you my parameter settings. Hope you get it worked out in the mean time.
Old Jan 5, 2007
Jap-Euro Fusion
Well thats what I said I'm trying to do ... but I think there's a wire into the blue box and a wire out. I don't know which ones to connect.
Old Jan 5, 2007
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
did you try to change the rotary setting to non vtec? Everything else should work as is and I'd assume that the ecu would still engage vtec.
Or just clip the vtec wire going into the harness and the one from the ecu and tie them back together thus eliminating the vtec signal coming from the Emanage.
Old Jan 5, 2007
Jap-Euro Fusion
Its definitely wired in there because the last time we tuned it we were changing the engagement point through the support tool. The problem is that it wont let it drop far enough to work right.
Old Jan 5, 2007
XSRCivic's Avatar
missed my reply?
Old Jan 5, 2007
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
i hear all about this emanage and how it is so good and sophisticated. witht hat said, isnt there a way to change when vtec kicks on in emanage? i would look into that, my next choice would to rewire it like u said an just run it into your honda ecu.
Old Jan 5, 2007
Jap-Euro Fusion
Originally Posted by XSRCivic
missed my reply?
Read the time stamps. YOu hit reply while I was typing.
Old Jan 5, 2007
Jap-Euro Fusion
There is, which is how I have it set right now. But if you read what I wrote, its holding it too high. Emanage modifies the voltage to the solenoid, thus engaging it on cue. Problem is the voltage can only be dropped so much, and the signal isnt working such that emanage will engage at 3200 like it should, it won't let it engage less at less than 5200, hence, I have a problem.
Old Jan 5, 2007
XSRCivic's Avatar
just rewire the vtec ecu wires back together, problem solved.
Old Jan 5, 2007
Jap-Euro Fusion
THANK YOU CAPTAIN OBVIOUS!!!!!!!!!!
Thats what I originally said.
But... the $64000 question... WHICH 2 WIRES?
Old Jan 5, 2007
XSRCivic's Avatar
Trace the wires going to those 2 vtec wires and presto! now wheres my $64000?
Old Jan 5, 2007
o ok i understand now. go with what xsr said sounds like he knows what hes doing, and dont forget to give him his 64000.lol.
Old Jan 5, 2007
XSRCivic's Avatar
Just calm down sparky, its the green/yellow wire that you need to put back together. I assumed since you are pretty knowledgable with this stuff that you could of figured it out. Good luck regardless.
Old Jan 5, 2007
Jap-Euro Fusion
I dont do wires.
And since I didnt have anything to do with wiring the harness, I have no idea what to cut and splice.
The Green/yellow wire is the VTEC wire into the ECU, I'm aware of that part... however.... all of the PNP harness wires are green, except the 16 that go to the blue box.... SO, of those 16 wires... there's either 1 wire that modifies the signal, or there's an IN and an OUT wire for the solenoid control. I need to know which one(s) of those need to be worked.
Old Jan 5, 2007
XSRCivic's Avatar
Its an in and out situation. Yellow is the IN Light Blue is the OUT. Clip those 2 wires from going into the emanage and tie them together. That will comlete the cicuit and essentially reconnect the ecu back to the solenoid without the emanage interfering.
This is difficult ro understand without pictures or being in person, I hope you get what I'm sayin.
solarpunk70
Apr 12, 2016 11:43 AM
Boosted2k2
Engine Swaps
31
Oct 20, 2007 04:25 PM
opto_isolator
20
Jul 2, 2004 09:37 AM
JohnyBlaze
Engine Swaps
Jul 3, 2003 03:29 PM
